helmuteke
#1 Posted : Sunday, May 13, 2012 9:50:16 AM(UTC)
helmuteke
hi ,
i know my first post here but i don't find the right answer :-(
i have a 3d printer and my daughter ask to print her name in 3d
So i thought to do it with viacad
so i make the text in 2D but i can't get it at 3D
please can someone tell me the right steps ??
tnx
helmut
ttrw
#2 Posted : Sunday, May 13, 2012 10:19:12 AM(UTC)
ttrw
Hi Helmut.
1. Using the text tool write your text.
2. Select all,
3. Then go to the menu bar at the top and choose "Edit" and "Change object type".
4 Choose "convert to curves".
Your text should be now ready to edit, and extrude, using the extrude tool.
I hope that helps. :)
Tom
ttrw
#3 Posted : Sunday, May 13, 2012 10:21:57 AM(UTC)
ttrw
PS, you can change your font in the inspector window too.
helmuteke
#4 Posted : Sunday, May 13, 2012 11:23:15 AM(UTC)
helmuteke
thnx for the reply
that did it
blowlamp
#5 Posted : Tuesday, May 15, 2012 3:33:36 AM(UTC)
blowlamp
You can also directly extrude text with the Extrude tool.
Please see the short video and be sure to use the Vector option to ensure the extruded letters all go the same way, as this is determined by which direction the curves in the text were drawn.
Also see how changing the font updates the solid.
http://screencast.com/t/kuMnL7g2u2y
Martin.
ttrw
#6 Posted : Tuesday, May 15, 2012 4:11:16 AM(UTC)
ttrw
Good input Martin. :)
That old chestnut has landed me in a pickle many a time!
