Birger
#1 Posted : Tuesday, March 20, 2007 8:18:15 AM(UTC)
Birger
Norway
Was thanked: 16 time(s) in 5 post(s)
Had to import a dxf template into maxsurf today.
DWG file from client is simple 2D projections. Imported fine into CU4 build 660, rotated and aligned for 3D view and tried to export dxf.
But export does not generate anything !
Ended up restarting CU, creating a new file, drew a single straight line - export still generates no result, no file , nothing.
Then in desperation saved client file as a CU2 file, opened in CU2, and guess what, - a dxf file was created on export! This imported fine into maxsurf.
Now, thats improvement for you....
Could anyone please check this out ?
Could anyone at "Punch" please make a set of test files and verify import and export for ALL files types for this build asap !
CU4 build660 version3 - OSX 10.4.9 SI metric system
