Redss
#1 Posted : Saturday, June 2, 2007 7:24:40 AM(UTC)
Redss
I need to make up some bodies to sit around a table.
If anyone would have some tips.
Thank You
bbuxton
#2 Posted : Monday, June 11, 2007 6:12:29 AM(UTC)
bbuxton
Japan
Was thanked: 35 time(s) in 16 post(s)
I would download DazStudio from
http://www.daz3d.com/i.x/softwa...73ba07c5a762bab4a7f755/?
Choose a low poly preset from their free content or search for a suitable poser file ie google whatever+poser
bring your cad model into DazStudio via dxf sit your figure on it delete cad model & export figure as dxf. Drop into Concepts/ViaCad.
If you want UV textures you will need to export for a 3D program that supports uv mapping and bring both cad model & figure there to render.
BB
Redss
#3 Posted : Monday, June 11, 2007 11:48:58 AM(UTC)
Redss
Thank You bbuxton
I will have to play with it I would like to turn them in to STL flie
for another e-Cabinet :) program
Clive Carter
#4 Posted : Monday, April 21, 2014 2:56:40 AM(UTC)
Clive Carter
You might look at:
http://www.cadhuman.com/
that contains the best CAD-suitable models of humans that I've seen so far. However, the trial that I had of a hand imported as *a whole*, rather than as a collection of parts.
I hope there might be a workaround, as the model is excellent.
Clive Carter
#5 Posted : Monday, April 21, 2014 2:58:19 AM(UTC)
Clive Carter
YOU might look at:
... that contains the best CAD-suitable models of humans that I've seen so far. However, the trial that I had of a hand imported as *a whole*, rather than as a collection of parts.
Tem
#6 Posted : Tuesday, April 22, 2014 11:52:39 PM(UTC)
Tem
Search for Make human
Guest (6)
