Redss
#1 Posted : Sunday, March 16, 2008 7:45:12 AM(UTC)
Redss
How do I seperate the attached DWG drawing into seperate layers or parts to create a diplay object?
I would like to trun it into a STL File so I can change all the colors on all the parts. The DWG file is from GE Co.I can not get it to work for me:mad:
Thank You George
r03680v-1.zip (355kb) downloaded 5 time(s).
nick
#2 Posted : Sunday, March 16, 2008 1:40:25 PM(UTC)
nick
Hello George
Sorry but it's just not going to be possible to split out all components, the file just contains a single mesh object. You will need to go back to the file's author and ask for original file with separate components.
All the best
Nick
Redss
#3 Posted : Sunday, March 16, 2008 2:38:38 PM(UTC)
Redss
Hi Nick
I was playing in TurboCad and turned it in to a 3DS File and got this :confused:
I am lost:(
Thank You Nick
r03680v-1.zip (600kb) downloaded 5 time(s).
Redss
#4 Posted : Sunday, March 16, 2008 2:46:43 PM(UTC)
Redss
Picture of the STL Files I got out of the 3DS File from TurboCad
Redss attached the following image(s):
nick
#5 Posted : Monday, March 17, 2008 2:09:07 AM(UTC)
nick
Hello George
Sorry but your posts are unclear, are you saying you loaded .dwg into TurboCAD then exported it from TurboCAD as a .3ds and then loaded it back into TurboCAD and exported a collection of .stl files?
Are the TurboCAD exported .stl files what you are looking for?
Best regards
Nick
Redss
#6 Posted : Monday, March 17, 2008 4:11:26 AM(UTC)
Redss
I took the dwg into TurboCAD and exported it as a .3ds and then loaded it back into ViaCad and exported it as a Stl File.I can not get all the layers to
change the texture on each one.I am trying to take it into e-Cabinet program as a Stl Files and change the textures of each one in e-Cabinets
Thank You Nick for taking the time with me
Redss
#7 Posted : Monday, March 17, 2008 4:19:08 AM(UTC)
Redss
Here is e-Cabinet program where I can change the textures
on most Stl Files
bmeissner
#8 Posted : Monday, March 17, 2008 4:51:02 AM(UTC)
bmeissner
George,
try this one. The DWG is a piece of crap, so it won't get any better. But at least the parts are separated...
Regards,
Bernd
r03680v-1.cu.zip (324kb) downloaded 5 time(s).
