                How do I seperate the attached DWG drawing into seperate layers or parts to create a diplay object?
I would like to trun it into a STL File so I can change all the colors on all the parts. The DWG file is from GE Co.I can not get it to work for me:mad:
Thank You George
 r03680v-1.zip
(355kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hello George Sorry but it's just not going to be possible to split out all components, the file just contains a single mesh object.  You will need to go back to the file's author and ask for original file with separate components. All the best Nick
                Hi Nick
I was playing in TurboCad and turned it in to a 3DS File and got this :confused:
I am lost:(
Thank You Nick
 r03680v-1.zip
(600kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Picture of the STL Files I got out of the 3DS File from TurboCad
Redss attached the following image(s):
(53kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hello George Sorry but your posts are unclear, are you saying you loaded .dwg into TurboCAD then exported it from TurboCAD as a .3ds and then loaded it back into TurboCAD and exported a collection of .stl files? Are the TurboCAD exported .stl files what you are looking for? Best regards Nick
                I took the dwg into TurboCAD and exported it as a .3ds and then loaded it back into ViaCad and exported it as a Stl File.I can not get all the layers to change the texture on each one.I am trying to take it into e-Cabinet program as a Stl Files and change the textures of each one in e-Cabinets Thank You Nick for taking the time with me
                Here is e-Cabinet program where I can change the textures
on most Stl Files
(90kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Redss wrote: How do I seperate the attached DWG drawing into seperate layers or parts to create a diplay object?
George,
try this one. The DWG is a piece of crap, so it won't get any better. But at least the parts are separated...
Regards,
Bernd
 r03680v-1.cu.zip
(324kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
