Missing Lib error message (#3533)
Trying to import a .skp file from sketchup. I get an error message saying missing library on these two files. Sketchupreader.dll and atl71.dll Both files are in the following location. C:\Program Files\Punch! Software\ViaCAD Pro v6\exe I did a default install, running windows 7 32bit Any suggestion on what I have I have wrong? Thanks Sorry this is in the wrong place, found the problem also reported by another user.
What build do you have? Tim
Download and install Microsoft Visual C++ 2010 Redistributable.
David Gross Dmg Design Colgate, Wi.
Running v6.0.0 build 852. Will look into the C++ 2010 Redistributable
Installed C++ 2010 Redistributable and rebooted the pc, still get same error message when I try to import a sketchup file.
Private email me and I will get you another build. Let's see if the newer build solves the problem.
tim.olson@evo-soft.net Regards
