nabed
#1 Posted : Thursday, February 14, 2008 4:56:15 AM(UTC)
nabed
Has anybody got experience in using the grid surface import?
I wonder if it would be possible to import vertices from SDS modeler (modo), by using this option.
(obviously an export script for modo or a conversion would be needed)
What is the file format for grid surface import? Is it just a text file containing point coordinates?
Any information would be appreciated (didn't find anything in the user guide or the forums)
Ciao, Norbert
nabed
#2 Posted : Thursday, February 21, 2008 9:46:25 AM(UTC)
nabed
Anybody???
#3 Posted : Friday, February 22, 2008 12:12:25 PM(UTC)
I've attached an example grid surface file.
Yes. It contains a MxN collection of points that are used to create a NURB surface that goes through the points.
GridSurfaceExample.dat.zip (2kb) downloaded 8 time(s).
nabed
#4 Posted : Monday, February 25, 2008 5:34:11 PM(UTC)
nabed
Thank You!
