Has anybody got experience in using the grid surface import? I wonder if it would be possible to import vertices from SDS modeler (modo), by using this option. (obviously an export script for modo or a conversion would be needed) What is the file format for grid surface import? Is it just a text file containing point coordinates? Any information would be appreciated (didn't find anything in the user guide or the forums) Ciao, Norbert
I've attached an example grid surface file.
Yes. It contains a MxN collection of points that are used to create a NURB surface that goes through the points.
GridSurfaceExample.dat.zip
(2kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
