                If I export a binary STL file, there is a warning when I open it in other programs. It says something like 'This file has the wrong length it may be corrupt'
                Bill, make sure that your units (ie mm) are set the same for all applications. Problems usually arise if one app is set for inches, whereas the other is set for mm's etc
                Originally Posted by: ttrw  Bill, make sure that your units (ie mm) are set the same for all applications. Problems usually arise if one app is set for inches, whereas the other is set for mm's etc
The app I am using (topescope) is a STL viewer/repairer. It doesn't specify units
                Originally Posted by: billbedford  The app I am using (topescope) is a STL viewer/repairer. It doesn't specify units
Do you get this message if you export a simple block?
Does it read it in, but gives you a warning?
                Ah yes Topescope. No units? That's like Cheetah3D. Utter madness if you ask me. You need to specify units- it's so important. Have you purchased Topescope, because if you haven't, ViaCAD makes a superb STL viewer (and the rest!) :D
                Originally Posted by: Tim Olson  Do you get this message if you export a simple block?
Simple meshes don't give the warning. I've never had any of the ones that do give the warning fail to read the file.
                Originally Posted by: ttrw  Ah yes Topescope. No units? That's like Cheetah3D.
Topescope is not at all like Cheetah, nor does it need to specify units.
Quote: Utter madness if you ask me. You need to specify units- it's so important. Have you purchased Topescope, because if you haven't, ViaCAD makes a superb STL viewer (and the rest!) :D
Sorry, but where are the commands to make ViaCad correct reversed normals, remove extra faces, repair holes and generally make meshes manifold?
                Originally Posted by: billbedford  Simple meshes don't give the warning. I've never had any of the ones that do give the warning fail to read the file.
It might be due to very small facets (near zero area).  We've seen this with some STL verification/repair programs.
You might want to try putting in an aspect ratio of 2 in the stl dialog box and see if that makes a difference.  This reduces small sliver facets.
                Originally Posted by: Tim Olson  It might be due to very small facets (near zero area).  We've seen this with some STL verification/repair programs.
Thanks Tim, I'll try that. My STLs tend to have a lot of very small triangles.
                Originally Posted by: billbedford  Topescope is not at all like Cheetah, nor does it need to specify units.
Yes I know Topescope is nothing like C3D in that aspect. Now I understand what you need it for- that's fine, but I very much come from the manufacturing background (not virtual) :)
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
