rockyroad_us
#1 Posted : Sunday, December 12, 2010 11:47:54 AM(UTC)
rockyroad_us
I'm having trouble with the two rail sweep function. See video below. The function appears to be failing. You see, the sweep follows the first rail but not the second rail. Any help is appreciated.
2railprob.sfx (17kb) downloaded 6 time(s).
2railprob_0.mov (156kb) downloaded 5 time(s).
zumer
#2 Posted : Monday, December 13, 2010 7:25:40 AM(UTC)
zumer
It gives a satisfactory result if you select the arc and chord, and choose two-rail swept solid rather than surface.
two rail solid.PNG (165kb) downloaded 5 time(s).
