rockyroad_us
#1 Posted : Wednesday, September 14, 2011 4:13:14 PM(UTC)
rockyroad_us
I have a 2d profile of a hose that I want to cross-hatch but the program won't do it. I'm able to extrude fine but I'm pulling my hair as to the reason for not able to cross-hatch this two portions with iron cross-hatching.
hatchingproblem.sfx (78kb) downloaded 4 time(s).
#2 Posted : Wednesday, September 14, 2011 6:24:22 PM(UTC)
Hi
If you activate the hatch tool then hold shift down and select each line or window select all lines it hatches.
rockyroad_us
#3 Posted : Wednesday, September 14, 2011 6:31:18 PM(UTC)
rockyroad_us
I see the solution is to select each line individually. I tried the select chain command as selecting all those lines individually is painful. I don't think the select chain command works fine with the hatching tool nor select drag command if one section is isolated and the other selected entirely. Thanks for trying out.
