I have a 2d profile of a hose that I want to cross-hatch but the program won't do it. I'm able to extrude fine but I'm pulling my hair as to the reason for not able to cross-hatch this two portions with iron cross-hatching.
hatchingproblem.sfx
(78kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Hi
If you activate the hatch tool then hold shift down and select each line or window select all lines it hatches.
(51kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
I see the solution is to select each line individually. I tried the select chain command as selecting all those lines individually is painful. I don't think the select chain command works fine with the hatching tool nor select drag command if one section is isolated and the other selected entirely. Thanks for trying out.
