Sluggish interface (#120)
Hello all. Am i the only one who feels that ViaCAD is somewhat sluggish when panning and zooming the drawing? I am not using a very complex drawing of anything (just a 2D imported from a DWG with 300KB), but, for me, it seems to slow to be usable! I already wrote tech support and sent the file in, but just wanted to know the general impression all of you have with the program. My computer is a macbookpro coreduo 2.0, with 2 gigs of ram, so i would expect it to work smoothly. On the plus side, i enjoy the interface and the mechanic of the program, and hope this situation can be solved so i can keep working with it! :) Cheers.
How are you viewing your files ? Any setting with hidden lines on is incredibly slow on a mac and almost unusable. Generally I try not to ever use these modes and stick to full wire frame (no dimming or hidden lines), or shaded.
Shark FX 9 build 1143
OS X 9.5
matter.cc
No, i am drawing in 2D, so no options to render. And the drawings are quite simple, with little over 300KB in dwg format.
>>Any setting with hidden lines on is incredibly slow on a mac We've got a plan to address this issue using some opengl technology from the home design products.
danieladro wrote: No, i am drawing in 2D, so no options to render. And the drawings are quite simple, with little over 300KB in dwg format.
Do you have drawing views? (Use Verify:Object Counts) and search for Drawing Views in the list. If so, try exploding the draw views to see if that speeds up your display.
Hi. Thanks for your attention to this matter. No, i don't have any drawing views. Anymore suggestions?
