3dup
#1 Posted : Monday, April 21, 2014 9:53:15 AM(UTC)
3dup
Was thanked: 5 time(s) in 3 post(s)
I have attached a pdf link to a enclosure there are made in solid works and printed on a 3D printer. Is it possible to make the enclosure drawing in VIACAD2D3D?
Link: [URL="https://www.dropbox.com/s/i9bnanhd947qg43/enclosure.pdf"]https://www.dropbox.com/s/i9bnanhd947qg43/enclosure.pdf[/URL]
Will it be complicated? I think it will, because I have played with the evaluation of VIACAD 5 days now, and can't get anything close to what I want?
Suggestions?
#2 Posted : Monday, April 21, 2014 3:43:46 PM(UTC)
Hello 3dup
Theres no need of advance surface modeling on this enclosure, so, Vicada 2d/3d can handle this one easily, it have enough tools for this as shelling, blending, and a few more that help
Start with an extrude of the basic block shape, cut the block with curves of desired shape, blend it, shell it, make holes and miscellaneous tasks,
This is an approach made on shark wit tools included on via cad, made on 20 minutes or so
[ATTACH]5038[/ATTACH]
Hope this help
caseaprox.sfx (1,803kb) downloaded 1 time(s).
MacOSX Sonoma 14.7.1
3dup
#3 Posted : Tuesday, April 22, 2014 1:18:29 AM(UTC)
3dup
Hi
Thanks for reply, 20 min. I have used days to figure how to do it?
Regards.
