                I was wondering if there was a better / faster way to skin these curves (layer geometry) than the way I did it. I tried several times to use the skin with guide option but, every time a non acceptable surface was made. Thanks for any advice......
                   Patrick
 DOME QUESTION.zip
(188kb) downloaded 6  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: PATRICK DRAKE  I was wondering if there was a better / faster way to skin these curves (layer geometry) than the way I did it. I tried several times to use the skin with guide option but, every time a non acceptable surface was made. Thanks for any advice......
Hi Patrick
You might want to also try the cover with guide curves.  With this surface option, the guide curves can cross each other.
Hi Patrick,
I'll be honest, so far the surface tools in VC have confused me, I think this is more down to me lack of using them. I see your method works ok but rather a lengthy process. In Rhino this is called a Network surface and I used your 5 curves to create the surface attached (brought into VC) the surface took 10secs to make ;)
Im about to download Shark and start testing so I would be most interested to see if you can build it in the same way & speed as Rhino....someone kindly put up an avi?? :D
 Dome_ph.vc3
(100kb) downloaded 7  time(s). You cannot  view/download attachments. Try to login or register.
                Tim,
                Below is a quicktime movie showing the dome surface created using a couple of surface types.
Net Surface (ViaCAD 2D/3D +)
--Add a point entity to the top and duplicate one of the arc cross sections to close.
Skin with Guide (ViaCAD Pro +)
--Add a point entity to the the top
Cover with Guide (Shark +)
Note isolines, not a degenerative surface as other types.
http://www.csi-concepts.com/Demo/videos/dome.mov Tim
Nice to see another Rhino face around these parts;) You have come to the right place if you wish to take advantage of the solid tools within VC and the Shark...im here for that very seem reason..Ohhh and also for M.T.O.S to produce drawings etc. I use my Rhino4 with VC all the time and I intend to keep it that way.....although VC/Shark will do 75% of what we do soon :D
btw: The reason I called it a network surface in rhino was down to _NetworkSrf
Tim Olson wrote: Below is a quicktime movie showing the dome surface created using a couple of surface types.
Thanks for the movie Tim !!
                Tim,
                Originally Posted by: Tim Olson  Below is a quicktime movie showing the dome surface created using a couple of surface types.
Tim, what is your formal definition of a "degenerative" surface?  I had a look at your CSi-Concepts advanced surfacing PDF, and it looks to me that it means that a number of u or v control points are coincident in space.  Is it that simple?  I don't know, and as a result it's somewhere between jargon and arcane invocation.
murray
                >>it looks to me that it means that a number of u or v control points are >>coincident in space.  Is it that simple?
                Why is that undesirable?  Does zero separation make parametrisation of the surface irrational at the coincidence point?  If that's the case, does the kernel choke and burp up the messages we see once in a while, or do you override with additional error handling?
                I also at first thought it was my lack of knowledge in the correct use of the surfacing tools, but the mov posted by Tim as shown I was using the tools correctly and it is just the output surfaces that are quite unexpected.
Looking at the examples:
Net surface. That produced a surface that was pinched at the join of the added curve pic 01 shows the surface in shark using zebra, the loss of tangency clearly shows.
Skin with guides: I currently have the shark demo version 5.5 build 823 for checking the surface tools, but cannot build the surface as shown. I am given an "Acis error" of "Net curves Intersections are not monotonic" (see pic 02)
Cover with Guide. The results where rather strange. Although the surface had continuity it was in ripples over the surface. I have attached a screen grab pic 03, but it does not really show how rippled the surface actually is.
I do use Rhino a lot for producing surfaces so ran a "surface from network of curves" and produced an acceptable result on first attempt, which I imported into shark for comparison. (pic 04)
(50kb) downloaded 6  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Tim.
Originally Posted by: Tim Olson  "Net curves Intersections are not monotonic" (see pic 02)
 Nice one.
Tim Olson wrote:  I'm not familiar with the Rhino network surface.  Does it require you pick mxn curve network?
By default Rhino will attempt to sort the curve order, it does work well most of the time, but sometimes Rhino will not be able to sort and will ask for manual input for the UxV curves.
Tim Olson wrote: Do you need to create a point?
No, I joined the 2 open curves and split the closed curve into 4 for the network (see pic).
The splitting of the closed curve was what I was originally doing in VC/Shark when I first started using the surfacing tools for that kind of surface, but always got the error "Surface U and V are in the same or opposite direction"
Regards,
- Steve
(23kb) downloaded 6  time(s). You cannot  view/download attachments. Try to login or register.
                >>Net surface. That produced a surface that was pinched at the join of the >>added curve pic 01 shows the surface in shark using zebra, the loss of >>tangency clearly shows.
                Hi Patrick,
There is no "skin with guide" option in VC, so I am not sure as to what tool you where attempting to use. The surface you posted, did you produce that in VC? If so by which method. I have looked at this but have not been able to produce a single surface that I find acceptable. I can split the surface construction up into a quad and skin, which surprisingly, does give good results (certainly not a method I would attempt in Rhino), so I am interested in your comstruction method.
Regards,
- Steve
                Originally Posted by: Tim Olson  I suspect this is because I used a point on the top and it does not have blend tangents for a point.
I will admit that I have not had much success when adding a point for a surface construction, but simply thought it my lack of knowledge on its use.
Is this then just a case of how Acis works?
More study and much more playing with VC needed.
Regards,
- Steve
                I am not at my laptop to try this, but would an alternate way of doing this be possible by intersecting solid spheres, then turning them to lines/surfaces? Before or after converting solid to surface, it might be possible to add iso lines or cutting planes or actual surfaces or shapes to use for cutting or dividing any lines/surfaces. This might get past the "unacceptable" or deformed surfacing...
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
