Tim Will Shark FX run on xp64.
David Gross Dmg Design Colgate, Wi.
>>Will Shark FX run on xp64. Yes it is our understanding it will (as a 32 bit app) but I have not had a lot of personal feedback on this configuration. If it's something you are about to purchase, you might want to double check by giving tech support an email or call. Tim
Originally Posted by: David Gross ...xp64.
I would avoid XP x64 in general because of the very lacking driver support.
If a 64 bit OS is really needed (i.e. more than ~3.x GB RAM in total, more than 2 GB RAM / application) Vista will probably be a better choice, at least if the video driver of the used graphics card does provide a reliable OpenGL support (go for a Quadro FX if you can).
Norbert
