Somethings not right (#910)
Attached is a file of 6 springs created in Concepts V4 and imported into Shark FX. When doing a model to sheet I can not create 2 section views without it taking a very long time and then before the first section view is done the program crashes after running out of memory. These are not complex parts. Can you check this out. On a PC with Windows XP and 4 gigs of memory.
 dmgdesign.zip
(531kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
    David Gross  Dmg Design  Colgate, Wi.
          Tim Olson  IMSI Design/Encore
                Tim were you able find anything on this issue yet. This did start with acis v17.
