David Gross
#1 Posted : Friday, March 21, 2008 2:26:13 PM(UTC)
David Gross
Attached is a file of 6 springs created in Concepts V4 and imported into Shark FX. When doing a model to sheet I can not create 2 section views without it taking a very long time and then before the first section view is done the program crashes after running out of memory. These are not complex parts. Can you check this out. On a PC with Windows XP and 4 gigs of memory.
dmgdesign.zip (531kb) downloaded 4 time(s).
David Gross
Dmg Design
Colgate, Wi.
#2 Posted : Friday, March 21, 2008 2:50:03 PM(UTC)
got it, looking into.
tim
David Gross
#3 Posted : Tuesday, May 13, 2008 3:34:05 PM(UTC)
David Gross
Tim were you able find anything on this issue yet. This did start with acis v17.
David Gross
Dmg Design
Colgate, Wi.
