Release version Shark FX build 737 wows (#833)
                Is anybody using the new Shark FX on a PC. I can not use this version, it has  major problems for me like, I can not offset a face on a solid model without zooming so far out that I can't even see the face that I want to offset anymore. I need to be able to zoom in very close to pick vary small faces. And the space ball only works with wire frame. There are probably more problems, but I stop using it with the few problems that I have found.
    David Gross  Dmg Design  Colgate, Wi.
                David, We were not able to get this to repeat in 737.  Can you download 738 and check again?  We were aware of the spacemouse problems in earlier builds but believe these are now fixed. Thanks Tim
    Tim Olson  IMSI Design/Encore
