David Gross
#1 Posted : Thursday, February 18, 2010 4:07:27 PM(UTC)
David Gross
Attached is simple model of a 1"x12" coil spring created in SharkFX V7. I am trying to create 2 views from a plan view of a front and right auxiliary view, but before it can finish I am running out of memory and the program crashes. running XP64 with 8 gig's of memory. Program crashes at about 1.7 gigs.
100X12 coil spring.zip (1,473kb) downloaded 0 time(s).
David Gross
Dmg Design
Colgate, Wi.
posh.de
#2 Posted : Friday, February 19, 2010 7:14:54 AM(UTC)
posh.de
Shark/VC are [URL="http://forum.punchcad.com/showthread.php?t=2816"]currently 32 bit applications[/URL] which therefore cannot access more than 2gb even under 64 bit operating systems.
Norb.
#3 Posted : Friday, February 19, 2010 12:04:42 PM(UTC)
Hi David,
I did a four view aok with V7 of this file. Are you using your own Layout or did you pick one from the list?
#4 Posted : Friday, February 19, 2010 12:47:16 PM(UTC)
Guys
It maxed memory and hung on Vista 32 bit. Std D Size Model to sheet Precise lines...
David Gross
#5 Posted : Friday, February 19, 2010 5:11:51 PM(UTC)
David Gross
I am using a top view sheet that I created with V7 and then making the auxiliary view off of that.
David Gross
Dmg Design
Colgate, Wi.
David Gross
#6 Posted : Friday, February 26, 2010 3:52:31 PM(UTC)
David Gross
Is this repeating for you because I use 4 to 20 springs in different dia.'s and lengths in every project I do and this repeats for me every time.
David Gross
Dmg Design
Colgate, Wi.
David Gross
#7 Posted : Wednesday, March 3, 2010 6:13:06 PM(UTC)
David Gross
Hello is there any one out there.
David Gross
Dmg Design
Colgate, Wi.
Tem
#8 Posted : Wednesday, March 10, 2010 4:56:05 PM(UTC)
Tem
Can you simplify the springs geometry in any way, or is there something hidden that consumes memory? I have only had this issue with files that are nearing the Gigabyte level.
