David Gross
#1 Posted : Friday, December 18, 2009 12:27:15 PM(UTC)
David Gross
When doing a simple hole to a depth is there any other way to get the drill point besides going to the object properties.
David Gross
Dmg Design
Colgate, Wi.
#2 Posted : Friday, December 18, 2009 12:30:36 PM(UTC)
It would be nice to have the drill point option at the top with the other hole data, so you can select when you create.
#3 Posted : Friday, December 18, 2009 12:32:03 PM(UTC)
No sorry, I was out of space to put in the data entry window.
David Gross
#4 Posted : Friday, December 18, 2009 1:34:33 PM(UTC)
David Gross
What about being able to pick multiple locations so that if you pick 20 locations the holes show up as 1 in the object properties box and therefore only have to edit 1.
David Gross
Dmg Design
Colgate, Wi.
#5 Posted : Friday, December 18, 2009 2:37:19 PM(UTC)
But, what if later because of element modeling or analysis it is decided to vary the size of symmetrical or assymetrical drill holes. If they are all one item in a parts tree, then geometry would have to be removed, changed, or added.
I would presume that some sort of database (a future feature) such as SQLite or whatever Tim can license inexpensively embed into ViaCAD and Shark would relationally handle the parts nesting/grouping so that one could pick affected parts and just resize/constrain them individually or pairs or according to hand-selected locations. This might have positive impacts on presentation and manipulation of parts.
Just some presumptions on my part...
David Gross
#6 Posted : Friday, December 18, 2009 5:37:56 PM(UTC)
David Gross
That work's for me and it took 10 YEARS to get the drill point.
David Gross
Dmg Design
Colgate, Wi.
