David Gross
#1 Posted : Friday, July 23, 2010 2:43:30 PM(UTC)
David Gross
I'm running Windows 7 64 and Sharkfx7 and when working sheets I am experiencing major screen redraws. Every time I select an entity the screen redraws. Every time I select a menu or window the screen redraws. If there is only 1 sheet view it only redraws 1 time, but if there multiple sheet views it redraws multiple times. If I have complex assembly of parts with 10's of thousands of entity's I am getting a continuous loop of screen redraws. Is anyone else experiencing this? I have called customer support and they said it's a problem in the software.
David Gross
Dmg Design
Colgate, Wi.
