idrawdreams
#1 Posted : Tuesday, August 31, 2010 4:24:07 AM(UTC)
idrawdreams
Linear Array in ViaCAD V7 Build 936 arrays in an unexpected orientation. In both 2D and 3D environments the tool appears to take the length of a rectangle or block object as the array orientation. In the array1 image, the object is a 2Lx4Wx1H block that has been arrayed in both the X and Y direction. In both cases the array is along the length of the block. Array2 shows the same size block, but with the length and width reversed, the array is again along the length of the block.
idrawdreams attached the following image(s):
