2 Pages<12
24c
#21 Posted : Sunday, November 8, 2026 5:40:45 PM(UTC)
24c
Was thanked: 95 time(s) in 63 post(s)
Hi
Just an update on Solidcraft etc, and the work done by Brennan, and others too helping this project.
The core engine is being updated, and for anyone who would like an update, this guy on YT gives and update…
https://youtu.be/g5BYODqilEM?is=PsOQuB5FfpCh6_Zj
…and here’s a link to the official site, there’s a cloned version called Solidcraft Pro, that’s a spam site etc. This is full parametric, and is starting to use the open source NVIDIA Rust based Kernel
Official link to Solidcraft
What’s fascinating is how people are using AI, and improving stuff, but if you’re not careful, it can send you down a rabbit hole, so the key in my experience is to ask proper questions, and give accurate feedback to problems you are witnessing.
Mike
PS I’ve used Plasticity years ago and it has come on since then, but I do hope a native Apple Silicon version drops someday, v18?, maybe some AI credits will go and sort some code analysis and bug fixes. I haven’t upgraded my macOS, as I don’t want to break the v16 I am running, because I have a load of files in saved in the .sfx formats.
macOS Tahoe-v17 beta b1908
24c
#22 Posted : Sunday, November 8, 2026 6:35:10 PM(UTC)
24c
Hi again,
Another one for you folks…
PhysCAD
Another YT link from the developer
PhsCAD YT
Early days, but it’ll do CAM and other options they are working on, it’s a one time purchase
Mike
thanks 4 users thanked 24c for this useful post.
ZeroLengthCurve on 11/8/2026(UTC), GARLIC on 11/9/2026(UTC), MPSchmied on 11/9/2026(UTC), damhave on 11/10/2026(UTC)
#23 Posted : Sunday, November 8, 2026 9:07:43 PM(UTC)
Was thanked: 129 time(s) in 88 post(s)
I saw it too. Impressive, whether or not vibe-coded.
It's apps like those that will light the fire 7nder incumbents. Ideally, if Tim and and Team can find opwn source or free (beer and rights/freedom) CAD core engine and kernel code, it xould be a massive win, as long as the code isn't so labyrinthian as to bog the Company down.
If those ascending/ascendant vibe coders keep adding features that turn out stable due to luck, perseverance, or community feedback, any existing companies that can't keep up won't survive outside of massively lobbying the pliant politicians.
As much as I hope those upstarts spook the incumbents, I really wish SharkCAD comes out a survivor.
But, at some point, filtering out IP infringement risk, the incumbents are GOING to have to more rapidly add stability, bug fixes, and begged-for quality of life add-ons such as:
— F2 to rename layers;
— ability to re-parent layers; permission to run multiple instances of the app to acoid crashing due to buggy files (imagine tutoring online and your files keep crashing unsaved work, and the viewers go, "Nahhh, I'll pass on that app...)";
— ability to drang and drop layers between app instances or even just one instance across multiple displays, so file reorg can be made more powerful;
— on-palette search dialogues; real-time intent-based curve fariring; more powerful and flexible constraints functionality (curves not planar!);
— and so on.
I don't have the kind of money it would take to get Tim or his board to add features I've begged for over the years. I bet even $1,000,000 wouldn't be enough since it can't be just Tim's decision. I could win a Powerball and try to no-strings drop $500,000,000 on SharkCAD and someone out of nowhere would get in the way, as if SharkCAD is supposed to be contained to some sideline niche — cute, but leashed. Powerful, but crippled. But, that kind of money would turn a vibe coder CAD company into a massively huge risk to incumbents. Heck, if 1,000 people put $100 a month into any one of those vibing CAD startup upstarts, the industry incumbents are going to cry foul.
Sharks are among the oldest and most powerful and most resilient animals on the planet. SharkCAD needs more teeth and improved gills. The seawater is only getting cloudier.
thanks 2 users thanked ZeroLengthCurve for this useful post.
GARLIC on 11/9/2026(UTC), 24c on 11/9/2026(UTC)
24c
#24 Posted : Monday, November 9, 2026 2:12:08 AM(UTC)
24c
Hi ZeroLengthCurve
Originally Posted by: ZeroLengthCurve Go to Quoted Post
I saw it too. Impressive, whether or not vibe-coded…… Sharks are among the oldest and most powerful and most resilient animals on the planet. SharkCAD needs more teeth and improved gills. The seawater is only getting cloudier.
Yes, I thought about the vibe coding side too, but I’ve been guilty of using that in parts for the last two weeks, trying to get my DIY programmable car ignition of the ground. Over years, like my CAD dabbling, I have tried to get it over the line, and despite having a load of experience with commercial systems, I wanted something simple, that a small segment of classic car (Panhard) owners could relate too. I last looked at it in February 2026 and some Arduino code using libraries wouldn’t work for me when I was checking it on an oscilloscope, no matter what, so I laid it up.
My point is two weeks ago, I fed some of the code into AI, described the symptômes, and in an hour it had homed in on the error, and then went down a prompt/reply rabbit hole for 5 days on and off, before I called time and fed my simple working code from two years ago into it, and said why don’t you use a simple interrupt model as I only need this type of triggering sensor trigger….well it just got better. Then I got to the limits of the is microprocessor, so asked if as we aren’t using this processor specific library aka core engine, can we not use any processor know, which it could, and within a few hours it had done just that, but I got sent down another rabbit hole, before I pulled it back, and changed direction again. This type of AI interaction where you see patterns, and ask questions, query responses etc I have found truly remarkable,
I now realise this is the strength of AI for me, I can ask a specific question, say this and this is happening, it will claw through the code, and explain what is happening, and why, suggest a fix, and in no time you’ve got a solution. I just wish that SharkCAD developers used this, maybe they have or will, just a simple compare CAD kernels exercise would be huge, and it’s amazing these start ups (individuals who are passionate) have got this far, even using AI to find fault with NVIDiAs open source kerne, sending the results back to NVIDIA, who fixed it is huge.
Another thing you notice, is that they are multi platform dependant from the off, including a Linux port etc, and Apple Silicon, I can’t help when Tim sees these sort of developments, his cogs will be turning, or even maybe somebody in his team, will try and use it to solve their pipelines of development.
I hope so, Sharks are needed in the ecosystem.
Mike
Edited by user Monday, November 9, 2026 2:14:23 AM(UTC)  | Reason: Usual stuff typos, and autocorrection.
ZeroLengthCurve on 11/9/2026(UTC)
relaxibus
#25 Posted : Monday, November 9, 2026 2:33:30 AM(UTC)
relaxibus
Was thanked: 89 time(s) in 51 post(s)
Price is ridiculous :-)
Features looks good for a sculptor modeller, not useable for mechanical and engineering applications, but this is not Cheetah's customer target.
For now, I'm keeping an eye on Plasticity and Solidcraft. As told, I love my Shark, but I'm angry we will not have a good way out here...
thanks 1 user thanked relaxibus for this useful post.
#26 Posted : Monday, November 9, 2026 5:40:27 AM(UTC)
Was thanked: 265 time(s) in 173 post(s)
PhysCAD YT looks very promising. (Thanks @24c)
I think once you've watched this video, you'll stop testing other software.
I just bought it, and I think all the other investments in CAD software were a waste of money.
Edited by user Monday, November 9, 2026 5:47:02 AM(UTC)  | Reason: Not specified
thanks 3 users thanked MPSchmied for this useful post.
GARLIC on 11/9/2026(UTC), ZeroLengthCurve on 11/9/2026(UTC), 24c on 11/10/2026(UTC)
GARLIC
#27 Posted : Monday, November 9, 2026 10:36:11 AM(UTC)
GARLIC
Was thanked: 105 time(s) in 67 post(s)
Just compare..........................................................................................
https://www.punchcad.com/sharkcad-17-pro-windows - 2,000.00 USD
https://physcad.io/ - 50,00 USD
Best Regards !
p.s.: Ø 1 license · 3 machines · win / mac / linux
Edited by user Monday, November 9, 2026 10:39:22 AM(UTC)  | Reason: Not specified
thanks 1 user thanked GARLIC for this useful post.
relaxibus
#28 Posted : Tuesday, November 10, 2026 2:35:39 AM(UTC)
relaxibus
I will also test PhysCAD, looks very promising. I tested Solidcraft, it opened large Step files quickly and the handling was very fast. But as soon I tried to move a connector, it hangs. So not very stable yet. Also it was not possible to copy & paste between files, very annoying!!
I love my Shark, but can't wait forever for a stable native Apple Silicon version and continue to pay upgrades. I stopped at v16 with MacOS 12.7.4. It works, quite stable, is ok but very very very slow if you group importer complex step files, almost unusable.
Let's see if this PhysCAD could be a good alternative. Is copy & paste between file available?
GARLIC on 11/10/2026(UTC)
#29 Posted : Wednesday, November 11, 2026 6:08:06 AM(UTC)
PhysCAD still seems to be missing quite a few features, but I like the fact that you can simply draw a sketch on any face and then extrude it. That opens up a whole new workflow. The newer applications also automatically determine the view rotation center, which saves you all the finger gymnastics required to change the rotation center in SharkCAD.
Zooming is a bit slow, and window zoom is missing. But then again, nobody seems to care about window zoom in SharkCAD anymore either, and the known bugs aren't being fixed.
We'll still need SharkCAD for certain tasks, so we haven't yet found anything that would allow us to completely give up our familiar old software.
GARLIC on 11/11/2026(UTC), ZeroLengthCurve on 11/11/2026(UTC)
relaxibus
#30 Posted : Wednesday, November 11, 2026 11:09:39 AM(UTC)
relaxibus
I started testing solidcraft wit the new kernel, very fast. However a simple task I frequently do in Shark on imported step file: just elect a hole and delete the inner face. Done, how gone. select a chamfer face, delete, gone. This is not supported on solidcreaft yet, very annoying.
Is this supported on PhysCAD?
The question is: solidcraft or PhysCAD? open source community driven vs a single man show?
If you could give some hints and experiences on both apps, would be great!
thanks 3 users thanked relaxibus for this useful post.
GARLIC on 11/11/2026(UTC), ZeroLengthCurve on 11/11/2026(UTC), MPSchmied on 11/12/2026(UTC)
#31 Posted : Wednesday, November 11, 2026 2:05:01 PM(UTC)
Yeh, the zoom issue that torques me and which generates unnecessary user counteraction is when switching between multiple drawings, the zoom ratio decreases by something like 3%.
So, when I try to compare two similar files and to disern my minor edits, the zoom ratio think forces me to have to hit "Zoom All" every single time. It's immensely immersion-breaking and induces expletives galore.
This is a MULTI-YEARS bug that should have never gotten into the wild (esp should never have made it past v9).
It's blatantly observable, inexplicable, is stress-inducing, there needs to be a patch issued backwards compatible to all versions. Even a simple script that recognizes that act if switching between drawings probably would take minutes to make and need no regression analysis. It just would be mimicking a time-wasting keyboard shortcut.
It's as stressful as the app never remembering my Show Points setting in-session. It surely cant be a problem. A script for that, too, could be out up on a page for us to download and be read each time the app opens. It's apparently in the settings text files, but not being acknowledged or honored, IIRC.
(BTW, I run all my sessions at the highest resolution setting. And the detail value to 0 so everything is as sharp as my graphics card can deliver to my screen.)
As for PhysCAD being able to extrude a sketch right off the face, that's definitely nice.
I sometimes see that SharkCAD's Push-Pull tool lets me pull a portion of a face according to the presence of a line or a spline and pull or push a straight or a curvy face. But, it's gas-lightingly intermittent. Or, my memory is bad. Or, maybe I need to reinstall.
When I get surprising and fun results, I feel like a kid in a candy store. Ehen SharkCAD gets in my way, or makes me do more work, well...
#32 Posted : Wednesday, November 11, 2026 2:35:00 PM(UTC)
I hope the Company has its own AI agentic app-building servers and that it is clean-sheeting and internally adversarial-y recasting SharkCAD from the ground-up. (But, whatever it is, it cannot cause or cast doubt on human-made content or cause a human to fail to obtain copyright registration. In that regard, my v12 of SharkCAD lacking AI features is a bonus, unless it's true that v16/v17 only aid, not originate content.)
A whole new functionality refresh might be just what the company needs.
I suspect that all the major CAD companies that don't already have deeply-nested data integration features (such as databases that manage worldwide collaborative activity in a file or nest of files) already are doing this as a matter of due diligence to remain relevant.
It's either burn tokens on the Web, or burn them locally. But, if they don't burn tokens and reinvent themselves, one-person shops are going to burn the beyond recognition and off the playing board.
CAD companies no longer have the lizury of fixed schedule release cycles and forcing upgrades for access to no-brainer bug fixes. Just as MS is having to sitch Patch Tuesday, any worthwhile CAD company is going to HAVE to release bug fixes and feature enhancements weekly, and still find a way to offer perpetual and off-line product versions.
I wouldn't mind paying $20-$100 for major offline, out-of-band fixes and feature enhancements.
But, strangely, the bugs I see simply often aren't what others report, and what they do report often aren't things that affect me.
Alternatively, SharkCAD needs to have a Grasshopper-like offering so people can create an ecosystem for SharkCAD to break out of its current mould. I do ships, not airplanes. I don't do Rhino, even though it with Grasshopper and Orca/Nemo/Swordfish, etc, are powerful combos.
I don't need endless spline offerings, surface patches, and similar. I need intent-based spline smokthing that won't upset my columns/rows counts of nor the general positions of my spline control points. Why? In SharkCAD, my manually drawn splines look mostly ok.
But exported as .iges (IIRC) and imported into FreeCAD... They look horrid, to sngular, not spline-y. I don't know if people will interpret it as me being sloppy/lazy/elderly-shaky-handed, or as a function of .iges import into other apps. Yet, splines made organically in a given CAD app look far better than mine imported into FreeCAD. An algorithm that looks at the genrale and scale and network-grid obviousness could do winders for SharkCAD so a user has less tedium in trying to balance, say, a network of hull-shaping and hull-fairing splines. (This would apply to users who draw with curves, added-on-to with surfaces, then whose surfaces are stitched, then shelled, and still need to look smooth. People sculpting with meshes might have less (or different) concern about certain precision nit licks.)
I've bleated on about layers enough. A Grasshopper-like ecosystem that is open to users, and not just to vendors or special partners, is absolutely sorely needed and overdue.
There needs to be a new symbiosis. Even sharks have tagalong fish (and parasites) riding along, symbiotically. I haven't seen animal videos about sharks grooming/scratching each other up each other like gorillas picking ticks and fleas from one another's pelts and crevices, so, those hitchhikers must not be too bad to have swimming along in company.
thanks 1 user thanked ZeroLengthCurve for this useful post.
memphisjed on 11/14/2026(UTC)
memphisjed
#33 Posted : Saturday, November 14, 2026 2:14:49 AM(UTC)
memphisjed
Was thanked: 18 time(s) in 15 post(s)
the beauty of Viacad / concepts / shark is the canvas heavy format, the simple pallets - and the layers of power you can get naturally. ok, recent switching back to Mac from years on windows and the shift/squiggle, or option, or control, plus another key is not as friendly as the control key only or control and one other key (pick a single key!!!!)- but still fluid. every other cad I have tried is to much at once other than cobalt/xenon which I know where realated at one time but now not.
learning a new cad sucks for someone who gets really used to one and can use it. I haven't met anyone who can really design well with fusion... its likely the worst interface I have seen or used in cad. I use the cam side daily, and still wouldn't wish the cad side on anyone. not only like they try to make cad interface convulted and with pop ups and half the screen not the design- it will change next week.. even worse.
I have to update from 16.. the snaps. I want the new extrude tool. holding off hoping for blackfriday deal as punch has done those. I didn't question getting 16 for Mac, had 15 on worthless windows laptop, have had numerous other versions, never needed to update other than for new computer over time. 8 still on my old laptop - solid, and 10? with the most functions before they started removing them (bulge, g2/g3) was favorite. 12? with 64 bit was crazy fast.
16, the snaps... the trade mark of viacad logicursor from turbocad days not working .. that just seems so odd to me to not have right. I don't mind paying for update:I really don't like paying for bug fix like this.
I am working on a few large projects where xref becomes nice again, I do wish that was still in vcp. I do wish we could have add ons, especially in Claude copilot code world, and third party options could be had.
thanks 2 users thanked memphisjed for this useful post.
MPSchmied on 11/14/2026(UTC), ZeroLengthCurve on 11/15/2026(UTC)
memphisjed
#34 Posted : Saturday, November 14, 2026 2:22:29 AM(UTC)
memphisjed
But exported as .iges (IIRC) and imported into FreeCAD... They look horrid, to sngular, not spline-y. must not be too bad to have swimming along in company.
iges is like dwg, everything between cad/viewer/writer has to be synced; and even then its funky at times. step has less information about what made the model but keeps a excellent geometry. dxf (2d), step 3d, is goto, no ambiguity.
#35 Posted : Saturday, November 14, 2026 3:32:26 PM(UTC)
I tested SolidCraft, and it failed miserably. It starts with the lack of basic drafting functionality. You can't even extend a line beyond the edge of the screen, and zooming while drawing a line isn't supported either.
It turns out that testing alternatives is just a complete waste of time.
GARLIC on 11/14/2026(UTC), ZeroLengthCurve on 11/15/2026(UTC)
murrayagain
#36 Posted : Saturday, November 14, 2026 5:14:41 PM(UTC)
murrayagain
Was thanked: 28 time(s) in 15 post(s)
There's an interesting one that's more reverse-engineering-oriented, scanruler.com. I intend to see how its analytic-surface-from-scan-mesh recognition compares to Shark's tool. It can be directly coupled to agentic AI as well, apparently. It uses OpenCascade kernel or whatever the most recent developments of that are called.
I'm aged and retired now, but in the early part of this century, in my line of work we looked at consumer devices that integrated capacity vs. modular devices, a dichotomy that exists today even in things as mundane as coffee machines: do you want an integrated grinder or a discrete standalone one that consumes more desk space? What happens if either module breaks down? Replace/repair the entire thing or is it an advantage to fix or replace one or the other? I settled into CAD with TurboCAD, and for some years there was agitation to incorporate this or that feature that another program had, or the way it worked for a particular workflow or feature. Then I digressed into ViaCAD to Shark, and arrived at where I'm pretty much agnostic. There's no entire one-stop-shop, and now I'll start work in this program or that dependent on what my clients or associates use and how they'll exchange to best advantage, but I've no ideological opposition to stepping outside for something that isn't available within that ecosystem.
I had a conversation once with Steve Hollister, the guy who programmed Pilot3D and ProSurf older-school maritime and surface design apps. Steve happily advised users to use Rhino along with his apps, but he was also trying to get people to adopt a system he was working on, this was just pre-COVID, that could plug various apps into a workflow, kind of an in-stream co-operative fashion. I haven't seen or heard of his project since then, but the idea's still intriguing. Proprietary behaviour being what it is, it'd be a hard task to get that to fly.
All of this has changed me in one way, though: Each program usually has customisable UIs, which I used to use in TurboCAD, but I stopped doing that because I found that in doing so, I tended to stick to the familiar and didn't use new features when they were introduced. One reason is that I was leary and perhaps a little intimidated by them, the other main reason is that using custom UIs meant that they weren't accommodated within the UI, if you don't see 'em, you don't tend to use 'em....
Edited by user Saturday, November 14, 2026 5:42:45 PM(UTC)  | Reason: Not specified
thanks 2 users thanked murrayagain for this useful post.
ZeroLengthCurve on 11/15/2026(UTC), MPSchmied on 11/15/2026(UTC)
24c
#37 Posted : Sunday, November 15, 2026 1:40:10 AM(UTC)
24c
@murrayagain
I’ve used Scanruler “created by” Stefan & AI from CNC Kitchen( a 3D print YouTube channel) and it’s pretty good along with his texture tool for 3D print surfaces, but what’s super interesting in OrcaSlicer, an open source fork of Bambu Slicer, which was derived from PrusaSlicer, and all of these have their roots in Slic3R and the RepRap 3D print movement 15 years ago, is that they have started to allow editing STEP files within their software,as well as textures and distorting 3D models besides the usual scaling. To get the STEP modelling, you have to enable “Parametric” in version 2.5 under Settings, and reboot, but it shows the direction this is going with open source adopting ideas from other projects and rolling them into each other.
PhsyCAD has had an update, as well as Solidcraft who has developed an open source mantra a bit like OrcaSlicer, where other developers with a skillsets have been collaborating, and both are responding to feedback from the community.
I do wonder how much of these developments are affecting the decision making at “punchCAD” HQ, especially as these are multi platform agnostic, whereas their existing kernel they are using isn’t.
Mike
PS I do remember the mesh to solid capabilities in SharkCAD years ago, but it used to take forever, and other than the price point, from a non-professional user standpoint, I’ve been very impressed with the latest update to Quicksurface with it’s AI mesh/point cloud to solid reverse engineering.
relaxibus
#38 Posted : Monday, November 16, 2026 3:20:38 AM(UTC)
relaxibus
I'm testing solidcraft from time to time (each new version) with a simple job: import a step and delete some chamfers and filets and faces (inside holes). Something we can do in Shark as a standard, but not available at solidceaft yet. For me a no-go for a switchover from CAD to CAD. PhysCAD seems working on this feature right now.
Being used to work on Shark since almost 15+ years, it's very hard to find another CAD that is really worth to move over. And it frustrates me I need to think about it. Why Punch will not wake up?? What's wrong with this guys? Are they not following this forum? We are telling them we all will move over to a new CAD if they don't change attitude, and nothing happen...
Anyway, for now solidcraft and PhysCAD are on my top favourites for now. @MPSchmied: Just open a tickets for solidcraft issues and improvements, they are quite reactive. I did this with the step face delete issues.
Just check the latest Release Notes: https://github.com/tange...aft/releases/tag/v0.43.0
When did you have seen a new Release Note on Punch??
Even PhysCAD have a new version: https://physcad.io/release-notes
"It turns out that testing alternatives is just a complete waste of time." So what is the alternative?
Edited by user Monday, November 16, 2026 3:26:58 AM(UTC)  | Reason: Not specified
thanks 2 users thanked relaxibus for this useful post.
damhave on 11/16/2026(UTC), GARLIC on 11/16/2026(UTC)
2 Pages<12
