#1 Posted : Sunday, August 9, 2026 2:23:49 AM(UTC)
Was thanked: 253 time(s) in 167 post(s)
I have encountered a reproducible snapping problem in all versions of SharkCAD.
After removing the original curves used to create the surfaces, snapping to the actual surface edges initially works correctly. In particular, vertices/corner points and midpoints of the outer boundary edges are detected correctly.
However, as soon as the view is changed — for example by using Dynamic View Rotation — these snap points stop working.
The main problem is that SharkCAD no longer detects the vertices/corner points and midpoints of the surface edges after the view has been changed.
The behavior is reproducible for me:
1. Open the CAD file.
2. Vertices/corner points and midpoints of the surface edges are detected correctly.
3. Change the view orientation or use Dynamic View Rotation.
4. Vertices/corner points and midpoints are no longer found by the snap system.
This appears to affect all versions.
It is possible that this is somehow related to my Windows installation or graphics configuration, so I would be interested to know whether anyone else can reproduce it.
Edited by user Sunday, August 9, 2026 2:26:23 AM(UTC)  | Reason: Not specified
GARLIC on 8/9/2026(UTC), L. Banasky on 8/9/2026(UTC)
L. Banasky
#2 Posted : Sunday, August 9, 2026 11:53:51 AM(UTC)
L. Banasky
Seems to work OK on Shark Pro Ver.12 PC.Win 11 I only use surfaces to split solids, so someone more
qualified might give a more detailed report. I just made a simple object, and a cover surface.
I do always get a warning when I delete the curves, sometimes the curves cause problems, especially
when moving.
