#1 Posted : Monday, April 13, 2026 8:53:37 PM(UTC)
When drawing a line that runs close to the x- or y-axis, the snap point is not used; instead, the line is drawn parallel to the x- or y-axis. I cannot work this way.I am going back to V 9.
Edited by user Tuesday, April 14, 2026 6:23:43 AM(UTC)  | Reason: Not specified
thanks 6 users thanked MPSchmied for this useful post.
GARLIC on 4/14/2026(UTC), damhave on 4/14/2026(UTC), jlm on 4/22/2026(UTC), L. Banasky on 4/22/2026(UTC), memphisjed on 4/23/2026(UTC), scruff007 on 4/28/2026(UTC)
#2 Posted : Wednesday, April 22, 2026 5:56:03 AM(UTC)
Yes, it is an issue.
It can generate mistakes.
In some cases we can solve it by zooming.
See video attached
Enregistrement de l’écran 2026-04-22 à 13.51.50-480.mov (2,656kb) downloaded 12 time(s).
thanks 3 users thanked jlm for this useful post.
L. Banasky on 4/22/2026(UTC), GARLIC on 4/22/2026(UTC), MPSchmied on 4/22/2026(UTC)
memphisjed
#3 Posted : Thursday, April 23, 2026 9:53:11 PM(UTC)
memphisjed
on Mac v16 the little snap to hoover doesn't work, and when it does the verbiage is ignored. like if you are pulling a line perpendicular to a curve the line will say perpendicular in the snap hoover then when mouse released the line is snapped to xy. frustrating.
thanks 1 user thanked memphisjed for this useful post.
MPSchmied on 4/24/2026(UTC)
#4 Posted : Monday, April 27, 2026 9:19:37 AM(UTC)
There is a solution for the problem. Write an email to support<at>punchsoftware.com, and Todd will send you Build 1841. This build is not available at http://www.masterviacad.com/beta/beta.php no also build 1841 works not properly, same problem.....
Edited by user Monday, April 27, 2026 9:55:54 AM(UTC)  | Reason: Not specified
memphisjed on 6/12/2026(UTC)
#5 Posted : Monday, April 27, 2026 12:19:32 PM(UTC)
Tim Olsen said via email that he fixed this problem in V17 builds, but he did not tell me where I can get V17.
Edited by user Tuesday, April 28, 2026 12:23:59 PM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, April 29, 2026 2:45:51 AM(UTC)
Yes, it seams to be OK now on V17 beta...
MPSchmied on 4/29/2026(UTC)
Guest (11)
