#1 Posted : Tuesday, February 24, 2026 6:40:17 AM(UTC)
Was thanked: 261 time(s) in 171 post(s)
The same issue occurs in builds 1826 and 1836.
I observed a similar issue when switching between Rotate three points and Rotate one point, but the error is a bit different there. And it works here when the buttons are freely positioned by pulling them out and then clicked.
