borisvp
#1 Posted : Sunday, January 25, 2026 5:50:45 AM(UTC)
borisvp
I recently bought ViaCAD 16 2D/3D (not pro) to replace my old V9. Since yesterday, I have tools missing in V16.
This is how it was before (in V16):
Tools OK
This how it is now:
Tools broken
Just the push-pull tool, nothing else.
There is also no menu entry (volume options) anymore.
So I opened a support ticket for which I didn't even get a receipt feedback, and cannot login or register with the support page since I'm either not authotized or my e-mail is already in use (of course it is, it's my customer account e-mail).
I found an old thread that they moved features from an older 2D/3D to a newer Pro, but would they do that in the same version?
Even worse, I can't go back to V9, since it does not open files saved with V16 and crashes when trying to import files which I have exported from V16 to V9 or older.
Any help on this from the community?
Boris
Edited by user Sunday, January 25, 2026 5:59:43 AM(UTC)  | Reason: Not specified
Bob La Londe
#2 Posted : Friday, February 6, 2026 1:56:21 PM(UTC)
Bob La Londe
I am not surprised. (Anecdote) I complained about a feature that didn't work on my last upgrade. Their answer was to delete the feature. I was stunned and just a little bit pissed off, but nobody responded to my complaint. Its also the reason I have refused to buy another upgrade.
The possible work around to your problem may be to "export" the file to a previous version of ViaCAD if that is supported in your current version. If it is supported then you can open the open the exported file in the version it was exported as.
12 days since you posted an no response. That's pretty sad to see.
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
#3 Posted : Wednesday, February 11, 2026 12:10:45 PM(UTC)
This is also happening to me a lot, but in Sharkcad pro V14 on MacOS
MacOSX Sonoma 14.7.1
DementedDwarf
#4 Posted : Friday, February 20, 2026 2:21:14 PM(UTC)
DementedDwarf
I am having the same problem
