Kartoffel
#1 Posted : Thursday, December 25, 2025 5:29:19 AM(UTC)
Kartoffel
Was thanked: 5 time(s) in 5 post(s)
I just upgraded to SharkCAD 16 and also bought the trainingguide.
Regarding the lasso select tool, used clockwise, only parts inside the points / band should be selected.
But there are always all parts selected.
I checked it with ShardCAD 12 - same result.
Do I use this tool wrong or is it a bug?
Theo5715
#2 Posted : Friday, December 26, 2025 2:44:20 AM(UTC)
Theo5715
Netherlands
Was thanked: 49 time(s) in 29 post(s)
Hi Kartoffel,
A lasso tool?
I'm using Sharkcad14 but never heard of a lasso tool in Sharkcad, just "select" or "deep select"
Can you explain what tool you mean?
Attach your file in the post so we can help you.
regard, Theo
Edited by user Friday, December 26, 2025 3:57:37 AM(UTC)  | Reason: Not specified
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
damhave
#3 Posted : Friday, December 26, 2025 4:46:17 AM(UTC)
damhave
Denmark
The lasso tool works correctly—at least in SharkCAD Pro v14 on macOS. Try drawing two rectangle polygons, then use the Lasso Select tool. If you draw the lasso clockwise, it will select only the objects fully enclosed within the lasso. If you draw it counterclockwise, it will select everything the lasso crosses.
I don’t use this tool frequently, so there might still be some bugs.
PS: If you use the Smart Polygon option, I’ve noticed it doesn’t behave as expected.
Edited by user Friday, December 26, 2025 4:50:27 AM(UTC)  | Reason: Not specified
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
24c
#4 Posted : Friday, December 26, 2025 10:25:15 AM(UTC)
24c
Hi, is that just because you can’t select any line in a Smart polygon if it’s not created as a Single Line Model
As an aside, anyone know of an easy way to convert a Smart Polygon to Single Line, as I’ve sometimes been caught out with this when editing later
Mike
macOS Tahoe-v17 beta b1908
damhave on 12/26/2025(UTC)
damhave
#5 Posted : Friday, December 26, 2025 10:35:47 AM(UTC)
damhave
Denmark
It also works in SharkCAD pro v15 on Windows...
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
damhave
#6 Posted : Friday, December 26, 2025 10:40:06 AM(UTC)
damhave
Denmark
Change Object Type... can convert from Smart Polygon to Single Lines
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
Kartoffel
#7 Posted : Saturday, December 27, 2025 1:20:41 PM(UTC)
Kartoffel
Ok, it was my fault. I tried it with some 3D spheres... With some polygones on the workplane, it works.
In the trainingsguide, it sais "The direction of the lasso will determine whether the objects are included or excluded from the selection. "
So, a sphere is/was an object for me...
Edited by user Saturday, December 27, 2025 1:33:26 PM(UTC)  | Reason: Not specified
