#1 Posted : Monday, December 15, 2025 9:31:59 AM(UTC)
When I import a spline (spl) file into Shark CAD Pro 16, it is imported in imperial units even though SharkCAD Pro is set to millimeters. So all values are displayed in mm multiplied by 25.4. For example, 1 is imported as 25.4 mm long. It’s the same error we used to have with important import formats in the past.
