MARTINEAUJL
#1 Posted : Sunday, November 23, 2025 5:54:36 AM(UTC)
MARTINEAUJL
In 3D mode with ViaCad 16 Pro.
No constraints enabled
Normal work plane (front, top, or side)
Polyline tool enabled
It's not possible to draw more than two segments by directly entering the coordinates.
This works perfectly in 2D mode.
Is there a specific technique for this?
Thank you for your answers and tips.
thanks 1 user thanked MARTINEAUJL for this useful post.
ZeroLengthCurve on 11/23/2025(UTC)
Theo5715
#2 Posted : Wednesday, November 26, 2025 11:29:04 AM(UTC)
Theo5715
Netherlands
Was thanked: 49 time(s) in 29 post(s)
Hi Martinraujl,
I work with Windows Sharkcad 14, build 1625 and no problems with it.
Perhaps you have to look at the preferences/user interface and select or unselect "use workplane coordinates in data entry"
Maybe this helps?
Regard, Theo
Edited by user Thursday, November 27, 2025 12:04:45 PM(UTC)  | Reason: Not specified
Theo5715 attached the following image(s):
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
thanks 1 user thanked Theo5715 for this useful post.
MPSchmied on 12/1/2025(UTC)
murrayagain
#3 Posted : Monday, December 15, 2025 5:34:52 AM(UTC)
murrayagain
Was thanked: 26 time(s) in 14 post(s)
If you've got the list of coordinates, it can be drawn as a 3D polyline by .spl file import, very simple text format. Head the list with POLYLINE, then one coordinate, tab delimited (tab between values, not commas or other punctuations), per line and give the text file .spl as the file attachment, then File|Import|spline and choose your text list. Maybe a workaround to whatever issue you're experiencing, a powerful tool in its own right.
thanks 1 user thanked murrayagain for this useful post.
MPSchmied on 12/15/2025(UTC)
#4 Posted : Monday, December 15, 2025 8:44:12 AM(UTC)
Good idea. You apparently get the points by displaying them with selecting and Ctrl+D. AND then you can draw the polyline and discard the spline curve. As far as I’ve tested, this doesn’t work with Edit > Change Object Type.
GARLIC on 12/15/2025(UTC), 24c on 12/15/2025(UTC)
murrayagain
#5 Posted : Tuesday, December 16, 2025 5:15:30 AM(UTC)
murrayagain
If POLYLINE is declared on the first line of the .spl file, that's the object you import, not a spline. You get a spline if you haven't put the declaration in the first line. Other entity/object types are also declared at the first line, THROUGHSPLINE, VECTORSPLINE, LAWSPLINE and LAWSURFACE.
thanks 2 users thanked murrayagain for this useful post.
GARLIC on 12/16/2025(UTC), MPSchmied on 12/18/2025(UTC)
