#1 Posted : Tuesday, November 18, 2025 2:32:44 PM(UTC)
Mexico
Hello, despiting the launch of Version 16 I am still working on von Sharkcad V14 build 1653 (1654 is not rendering model to sheet).
Im using Mac OS Sequoia 15.7.2 and I've noticed the color wheel spinning several times while I'm working; is very frustrating and exasperating, but worst of that, several times also computer ran to pause due to "Your System has ran out of aplications memory. To avoid problems with the computer, quit quit any applications you are not using"
And pop up window shows shark cad using an excessive amount of it in this case up to 128 gb (see attached picture)
quitting apps and try to resume sharkcad does not work at all, so need force to quit the application and of course loose the unsaved data.
I this normal? its a bug?
I been working with cam programs for thoes same files on virtualized windows with parallels and that does not happen, so, what is going on?
any one else has deal whit this issue?
Edited by user Tuesday, November 18, 2025 2:36:40 PM(UTC)  | Reason: misspelling
MacOSX Sequoia 15.7.7
