Thanks: 52 times Was thanked: 94 time(s) in 62 post(s)
Hi
Anyone having issues with macOS Tahoe and Shark CAD Pro.
It's leaving drop down menu items on the desktop, needs a Quit to resolve
Force Quit doesn't show it "Not responding" though
My beta for v16 has expired, so can't test that.
Cheers
Mike
PS I'm trying to open Recent Items in the drop down, so maybe the file structurer has changed, as it crashes and quits trying to open some of these files.
Edited by user Tuesday, September 16, 2025 6:52:37 AM(UTC)
| Reason: typo
(867kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Hi, since switching to Tahoe, I get serious trouble working with Shark pro 14.1.0 (Build 1654). Drop down menus stoped working, also tools like extrude stopped working, since no object can be selected. Will this be fixed? Thanks, Robert
Hi Robert, I'm on the same build, and I'm getting more issues, sometimes the Entity what show the ops, and I can't expand in Concept Explorer to alter chamfers etc Tried quitting and re-booting, but no joy. Definitely an issue with screen redraw and updating, as highlighting a part doesn't update the open window in concept explorer Very frustrating, but I'd be interested if anyone is OK using a 16 Beta or a later build of 15. I see the forum has been pretty quiet, not sure if it's monitored by support. Mike
Hi again Just an update in Concept Explorer, if I click on a part in the drawing, it is not identified in Concept Explorer's Entities tab, but if I click on Layers or Symbols, when I go back to Entities I can se the History Tree, so evrytime it locks out, and becomes unresponsive, I just switch into another tab, and then back to the original tab.... something simple, that's changed in the macOS side, that's not playing nice. :) Mike
Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Hello,
With SCP V16 b1732 :
I can confirm many interface issue as mentioned before for V15 :
Menus defect, tools changing icons, Explorer loosing control....
But let's see a
positive point : there is far less crashes and hangs than before upgrading to Tahoe.
Hatching complex sections copy and paste or export heavy solids are working better than ever.
---> May be a Rosetta finally learned Shark's language ???
Edited by user Thursday, September 18, 2025 9:04:07 AM(UTC)
Thanks for that, I'm hoping the software team are on the case, not being negative just surprised, and BTW for me, the V16 Beta was a big improvement in a few areas vs previous beta tests. Maybe I shouldn't have "upgraded" to macOS Tahoe. :)
Mike
PS I suspect it's more to do with graphics engine changes, or newer guidelines not yet adopted.
Originally Posted by: jlm With SCP V16 b1732 : I can confirm many interface issue as mentioned before for V15 : Menus defect, tools changing icons, Explorer loosing control....
Thanks: 3 times Was thanked: 11 time(s) in 9 post(s)
I cant create or delete layers in the layers palette...
Claus
OK, this seems to be related to using external monitor in my case. If I open my macbook both displays will update. So clicking to create a new layer actually creates the layer but it will not show until a screen update is invoked. As a workaround I have my laptop close to my left hand and lift the lid to refresh. Hopefully not for long.
Edited by user Friday, September 19, 2025 2:36:34 AM(UTC)
Originally Posted by: Claus3 OK, this seems to be related to using external monitor in my case. If I open my macbook both displays will update. So clicking to create a new layer actually creates the layer but it will not show until a screen update is invoked. As a workaround I have my laptop close to my left hand and lift the lid to refresh. Hopefully not for long.
Hi Claus,
I'm using an external monitor with my MacBook open, but useful to know.
I'm not sure how long before there is a fix for v14, as I suspect it'll roll into a v16 upgrade. My understanding sometime ago was the software team don't have access to an Apple Silicon Mac or use an external monitor, but I'm not sure how many macOS users there are using their software vs Windows OSes
Mike
Originally Posted by: Claus3 I cant create or delete layers in the layers palette... As a workaround I have my laptop close to my left hand and lift the lid to refresh. Hopefully not for long.
Clever Workaround Claus !
On my side, I have set collapsible layer palette.
Collapsing and expending the palette does the same refresh...
Too bad it doesn't solve the entity tree...
JL
Thanks: 355 times Was thanked: 261 time(s) in 171 post(s)
Originally Posted by: jlm collapsible layer paletteL
Do you mean the Concept Explorer or a "collapsible layer palette"?
I emailed Tim Olson and he is working on it...
1 user thanked Claus3 for this useful post.
Great tip, much easier. Thanks!!
Originally Posted by: jlm Originally Posted by: Claus3 I cant create or delete layers in the layers palette... As a workaround I have my laptop close to my left hand and lift the lid to refresh. Hopefully not for long.
JL
Originally Posted by: jlm Too bad it doesn't solve the entity tree...
I find if I switch back and firth in Concept Explorer when looking at the Entities that don't show anything, that switching to Layers and switching back is enough to force a refresh and see the history... then you can go into this, but anytime it locks out or doesn't update say when Remove Feature etc, I just switch somewhere and switch back.
Works for me, just doing frequent saves too. :)
Mike
Was thanked: 3 time(s) in 1 post(s)
Giving this a bump. Has anything been done? I have VC Pro 15 and it is useless with Tahoe - the program hangs constantly (my only option is a force quit), Concept Explorer doesn't work: can't hide layers, can't switch focus, can't create new layers (truth to tell it does create the layer but doesn't show it in the CE so I can't use it). I don't know if there are other errors because the program hangs within minutes. It is NOT usable. Oscar
3 users thanked neotericsimian for this useful post.
Thanks: 16 times Was thanked: 7 time(s) in 4 post(s)
Hi. The question is: When V16 will be out as it seems the only one that work with Mac OS 26? Turbocad Mac 16 is already available, so why Sharkcad / Viacad still waiting?
I am new to viaCAD 15 for the Mac and have experienced the same refresh problem with Concept Explorer. I accidentally stumbled on the workaround already mentioned of switching from the Layers tab to any other tab (Entities, Symbols, Co-pilot)then switching back to the Layers tab. I am running viaCAD 15 v15.0.15 Build(1722) / Tahoe (macOs 26.0.1) / Mac mini M4, 24GB Ram, booting from an external 2TB M2 SSD. I've had a few crashes and freezes but haven't lost anything important yet. I am switching to CAD software that will run natively on the Mac. I have been running TurboCAD for Window on virtual machines for at least 25 years. I tried for days to get TurboCAD running but couldn't. Here's what did not work for me: TurboCAD/Windows11/VMware Fusion 13/Tahoe/Mac mini M4. -Nelson
V.16 is finally out today:
https://www.punchcad.com It's Mac OS Tahoe compatible.
1 user thanked Ovocom for this useful post.
Originally Posted by: Ovocom Here is the link to the description:
https://www.punchcad.com...dtm-sharkcadr-viacadr-16 I think I need to buy this upgrade because what I really need is faster redraw and loading.
Edited by user Wednesday, October 22, 2025 12:49:00 PM(UTC)
Thanks: 8 times Was thanked: 8 time(s) in 6 post(s)
Originally Posted by: 24c Hi again that's not playing nice. :) Mike
I'm with you.
I'm waiting for
a accommodating agreement
for all of us. who do not need the upgrade, but have to do it
best wishes Andreas since ViaCad 5 with punch, now > SharkCad 16 , Mac
Originally Posted by: Claus3 I emailed Tim Olson and he is working on it...
any answer ? Tim is the soul of punchCad . Hope she rest will understand
1 user thanked andreaswieneke for this useful post.
