Thanks: 38 times Was thanked: 63 time(s) in 45 post(s)
Hi
Anyone having issues with macOS Tahoe and Shark CAD Pro.
It's leaving drop down menu items on the desktop, needs a Quit to resolve
Force Quit doesn't show it "Not responding" though
My beta for v16 has expired, so can't test that.
Cheers
Mike
PS I'm trying to open Recent Items in the drop down, so maybe the file structurer has changed, as it crashes and quits trying to open some of these files.
Edited by user Tuesday, September 16, 2025 6:52:37 AM(UTC)
| Reason: typo
(867kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Hi, since switching to Tahoe, I get serious trouble working with Shark pro 14.1.0 (Build 1654). Drop down menus stoped working, also tools like extrude stopped working, since no object can be selected. Will this be fixed? Thanks, Robert
Hi Robert, I'm on the same build, and I'm getting more issues, sometimes the Entity what show the ops, and I can't expand in Concept Explorer to alter chamfers etc Tried quitting and re-booting, but no joy. Definitely an issue with screen redraw and updating, as highlighting a part doesn't update the open window in concept explorer Very frustrating, but I'd be interested if anyone is OK using a 16 Beta or a later build of 15. I see the forum has been pretty quiet, not sure if it's monitored by support. Mike
Hi again Just an update in Concept Explorer, if I click on a part in the drawing, it is not identified in Concept Explorer's Entities tab, but if I click on Layers or Symbols, when I go back to Entities I can se the History Tree, so evrytime it locks out, and becomes unresponsive, I just switch into another tab, and then back to the original tab.... something simple, that's changed in the macOS side, that's not playing nice. :) Mike
Thanks: 222 times Was thanked: 171 time(s) in 103 post(s)
Hello,
With SCP V16 b1732 :
I can confirm many interface issue as mentioned before for V15 :
Menus defect, tools changing icons, Explorer loosing control....
But let's see a
positive point : there is far less crashes and hangs than before upgrading to Tahoe.
Hatching complex sections copy and paste or export heavy solids are working better than ever.
---> May be a Rosetta finally learned Shark's language ???
Edited by user Thursday, September 18, 2025 9:04:07 AM(UTC)
Thanks for that, I'm hoping the software team are on the case, not being negative just surprised, and BTW for me, the V16 Beta was a big improvement in a few areas vs previous beta tests. Maybe I shouldn't have "upgraded" to macOS Tahoe. :)
Mike
PS I suspect it's more to do with graphics engine changes, or newer guidelines not yet adopted.
Originally Posted by: jlm With SCP V16 b1732 : I can confirm many interface issue as mentioned before for V15 : Menus defect, tools changing icons, Explorer loosing control....
