SharkCAD 16 Pro Upgrade from SharkCAD Pro 15 Mac
Hey everyone,
Edited by user Friday, April 18, 2025 8:41:20 PM(UTC)
(277kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Brian Graham Mac OS Sequoia 15.4.1 Mac mini 2024 Apple M4 24GB 1TB SSD Shark FXv 15 Build 1722
Thanks: 342 times Was thanked: 228 time(s) in 156 post(s)
Originally Posted by: grahamdesign Is there a version 16?
No.
https://www.punchcad.com/product-line-comparison OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB | Graphic: AMD Radeon RX 7900 XT | SharkCAD 17 Pro | Unit: mm
Hi Brian
https://forum.punchcad.com/default.aspx?g=posts&t=11166#post43191 V16 New Features http://www.masterviacad.com/videos/page13/index.html V16 Copilot Improvements http://www.masterviacad.com/copilot/cad/index.html Tim
Edited by user Thursday, May 22, 2025 6:34:15 PM(UTC)
Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
Hi Tim, I cant log in to my profile Claus2 so created a new Claus3. However I can’t access the beta section of this forum, can you help. Are you planning to release a but fix for v15? I did report that protrude solid is not currently working. Thanks, Claus
Thanks: 7 times Was thanked: 79 time(s) in 45 post(s)
V16 New Features http://www.masterviacad.com/videos/page13/index.html All questions for MacOS
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Hi, I've just downloaded SharkCAD build 1732 to check the extrude from a face issue. I'm getting a repeated crash immediately after opening the app (Mac version). Nick
>>I've just downloaded SharkCAD build 1732 to check the extrude from a face issue. I'm getting a repeated crash immediately after opening the app Checking.... Tim
Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I hope they start fixing all the bugs... Also support for silicon prossecor. There isn't any development anymore. And support..anybody there?
3 users thanked relaxibus for this useful post.
Thanks: 33 times Was thanked: 23 time(s) in 20 post(s)
Luis G.
Originally Posted by: Tim Olson
I just installed ViaCAD 16 2D. Shocked to discover it is STILL not written for Apple Silicon. Apple Silicon is over 5-1/2 years old. I'm running OS 26.5. It's almost a certainty that MacOS 27 will no longer include Rosetta.
The current beta version is
v17 Build 1912 .
V16 has a significant error with snaps. When the second point of a line is near the XYZ axis, it snaps to the axis and not to the snap point. It seems this glitch will only be fixed in
v17 .
Edited by user Saturday, June 6, 2026 9:04:06 AM(UTC)
2 users thanked MPSchmied for this useful post.
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Just noticed on Apple Insider that support for Apple Silicon (Rosetta 2) is ending is imminent ....
see >
Apple Insider Article Why pay for upgrade to TC17, which seems not to be made for Apple Silicon, if "Fall 2026: macOS 27 releases, uninstalling Rosetta 2"?
1 user thanked Frednet for this useful post.
Rosetta support is still included in the next MacOS. Support for intel based software will be removed fall 2027 except for some games(source:Gemini). Curious about the future for Shark and turbocad Mac I asked the sales department of IMSI and got this fast response that I find quite positive: “Thanks for reaching out regarding the Apple Silicon compatibility. SharkCAD 16 Mac currently supports Apple Silicon using Rosetta 2. We are actively working on supporting native ARM based Apple silicon. I don't have an exact release date right now, but we expect to have an update on the roadmap by later this year.”
1 user thanked Claus3 for this useful post.
I fear that the port to native Apple Silicon will lead to a completely new code stream and thus either to the end of the Windows version or to a doubling of development resources.
Who is going to port the ACIS kernel to native mac silicon?
Originally Posted by: Albatrossflyer Who is going to port the ACIS kernel to native mac silicon?
Quote: Yes — the ACIS kernel itself has already been ported to Mac ARM / Apple Silicon by Spatial/Dassault: the official Spatial release notes for
3D ACIS Modeler 2023 1.0 explicitly mention “MAC ARM platform support”.
Source:
Spatial: 3D ACIS Modeler 2023 1.0 Release Notes For
SharkCAD/ViaCAD , however, the situation is more nuanced:
In short:
Yes, ACIS itself exists for Mac ARM. Whether
SharkCAD/ViaCAD/TurboCAD Mac already use the kernel and the full application pipeline natively is a different question — based on the current forum information, SharkCAD 16 still appears to depend on Rosetta.
For CAD users, this matters because Apple will only provide Rosetta generally up to
macOS 27 ; starting with
macOS 28 , Rosetta is expected to be available only in a very limited way for certain older games.
Source:
Apple Support: Rosetta 2 and future macOS versions In the Shark context, ACIS is indeed the relevant Spatial kernel; the Shark FX/LT manual identifies ACIS as a registered trademark of Spatial and refers to Spatial copyright portions.
