Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
Hello
Im using Viacad 12 with WIN 11.
I have a problem to substract solids. I allways get the following ACSI Error:
system inconsistency processing surface tangancy
Can someone please help me. Thanks.
kind regards
Martin
Substract Solid.vcp
(1,981kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Martin Krueger ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D _myMill self made CNC milling-machine
Thanks: 316 times Was thanked: 190 time(s) in 135 post(s)
Did you create this wing with ViaCAD? This solid may have too many overlaps.
(577kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: MPSchmied Did you create this wing with ViaCAD? This solid may have too many overlaps.
Yes, I created it with ViaCAD. Now I recreated it and it worked, thanks. The question that remains is - why did function Add Solid leave the overlap?
kind regards
Martin
1 user thanked martinwh99 for this useful post.
Thanks: 8 times Was thanked: 26 time(s) in 15 post(s)
Hi Martin,
It looks like your second part is not a proper solid
Theo5715 attached the following image(s):
(14kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
If things don't go the way you would find a way it could.
