2 Pages<12
ale
#21 Posted : Tuesday, February 18, 2025 3:02:21 AM(UTC)
ale
Sorry I don't use the software anymore, just here to try and help. If you send me the dxf I can resize it for you?
Problem is, i can open a old DXF file from my computer and open in viacad 15, also than is a old file all 25.4 x bigger.
i think you can this for me resize and send back, than when i open this is again 25.4 x bigger
Theo5715
#22 Posted : Tuesday, February 18, 2025 5:00:21 AM(UTC)
Theo5715
Netherlands
Was thanked: 33 time(s) in 20 post(s)
Hi all,
1) The support of 24/7 means only support at 24 Juli, hopefully this year
2) Did anyone try to use constraints?
regards, Theo
Edited by user Tuesday, February 18, 2025 5:04:57 AM(UTC)  | Reason: Not specified
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
ale
#23 Posted : Tuesday, February 18, 2025 7:29:33 AM(UTC)
ale
What's interesting is that a Mr. Todd Quinlan gave a good answer when it came to the extension from version 10 to 15 at the email address given on the website, daily. Now that the problem has existed, there has been no response to emails and questions. well, it sucks
#24 Posted : Tuesday, February 18, 2025 3:12:42 PM(UTC)
Your settings are not being saved correctly, making it pointless to continue working. Try uninstalling and then reinstalling the software, ensuring that the permissions are set correctly. It is possible that your security settings are too high for the software. Alternatively, you can try running the software with administrator rights to allow it to save the settings.
Which build do you using?
#25 Posted : Tuesday, February 18, 2025 3:27:33 PM(UTC)
someone can check here in the files whats the Problem? vc is original size. dfx is 25.4 x bigger.. whats wrong in this export?
vc3 is correct
dxf is 25.4 x bigger
I have opened your VC3 files, and they are displayed 25.4 times larger on my system. When will the imperial system finally be banned by law worldwide? It drives me crazy too!
Edited by user Tuesday, February 18, 2025 3:32:39 PM(UTC)  | Reason: Not specified
Clipboard 1.png (183kb) downloaded 2 time(s).
#26 Posted : Tuesday, February 18, 2025 3:41:01 PM(UTC)
vc3 is correct
Abdeckungen Küche Abzug hat die richtige Größe wenn ich es öffne.
Clipboard 2.png (116kb) downloaded 2 time(s).
#27 Posted : Tuesday, February 18, 2025 3:50:38 PM(UTC)
here the second file only in vc3.
i need this in dxf for lasercutting.
thanks for answers
Ich habe dei DXF mal richtig exportiert. Im Export Import Dialog kann man die Einheit auswählen. Lol, I opened it in TurboCAD, and it was 25.4 times bigger. I need to do more testing myself. When I open it in SharkCAD 15 using the Open function, it also appears 25.4 times bigger, but when I import it using the Import function, it has the correct size.
Edited by user Tuesday, February 18, 2025 4:27:20 PM(UTC)  | Reason: Not specified
#28 Posted : Tuesday, February 18, 2025 4:17:52 PM(UTC)
When I open your file Laserplatten Marmorieren.vc3, the units sometimes switch to imperial. This is a really bad bug, and I think I now have the same problem. However, I don't have this issue with new files that were created in millimeters.
#29 Posted : Tuesday, February 18, 2025 4:30:28 PM(UTC)
thanks for answers
So, I opened your file in millimeters (you need to have another file in mm open first to prevent the program from switching the units to imperial). Then, I scaled it down to the correct size. It should now work for laser cutting. And I exported the other file correctly.
Edited by user Tuesday, February 18, 2025 8:21:32 PM(UTC)  | Reason: Not specified
#30 Posted : Tuesday, February 18, 2025 8:00:37 PM(UTC)
vc3 is correct
In the file Abdeckungen Küche Abzug.dxf, there is a problematic design element: 'Rounded Rectangle'. This is problematic for laser cutting and is exported as a polyline into the DXF file. I have converted it into lines and arcs for you. This works in ViaCAD via File > Change Object Type > Curves. Instead of creating curves, it converts them into lines and arcs. If you simply open the DXF using the Open function in ViaCAD, it will be imported incorrectly. This seems to be a bug in version 15. Therefore, always use the Import function with the correctly set unit to check it.
Edited by user Tuesday, February 18, 2025 8:19:12 PM(UTC)  | Reason: Not specified
Abdeckungen Küche Abzug.dxf (703kb) downloaded 1 time(s).
Abdeckungen Küche Abzug.vc3 (14kb) downloaded 1 time(s).
Laserplatten Marmorieren.dxf (706kb) downloaded 1 time(s).
Laserplatten Marmorieren.vc3 (19kb) downloaded 1 time(s).
thanks 4 users thanked MPSchmied for this useful post.
GARLIC on 2/19/2025(UTC), damhave on 2/19/2025(UTC), ale on 2/19/2025(UTC), MaiFy on 2/19/2025(UTC)
rockyroad_us
#31 Posted : Thursday, February 20, 2025 10:26:21 AM(UTC)
rockyroad_us
vc3 is correct
Maybe your export is not working well. Be sure to have export in mm.
2 Pages<12
