bookmiester
#1 Posted : Monday, January 27, 2025 6:45:06 AM(UTC)
bookmiester
Hello Guys
I am not able to print anything from viacad without it hanging up. I used to be able to pint only once but I had to setup the printer settings first within viacad, save it, then close and reopen the application and it would print only once. Not sure what has changed but I cant even do this anymore. Maybe the file I have is larger than normal but I am only trying to print 1 page of the "model to sheet" feature. No luck.
#2 Posted : Monday, January 27, 2025 1:44:58 PM(UTC)
I have never seen such behavior from the software before. Which version are you using?
MaiFy
#3 Posted : Wednesday, January 29, 2025 2:04:12 AM(UTC)
MaiFy
Hi Book meister.
They have had problems with the printing interface before.
I would report it to support and hopefully the may resolve it.
I had problems with version 14 until they fixed it.
Here are a couple of threads regarding earlier versions.
https://forums.punchcad....aspx?g=posts&t=10953
And this is a cut and paste from the Beta 14 thread.
Quote
"Tim Olson Posted: 10 months ago
We've updated the V14 builds for ViaCAD, SharkCAD, and TurboCAD Mac to build 1654.
These builds can be downloaded at :
http://www.masterviacad.com/beta/beta.php
Build 1654 Change Log
--Issue printing to PDF and blurry or double lines
--Crash correction on some machines regarding unknown file types
--Crash correction for exploding very large assemblies
--Correction with clash analysis tool and results
I'm also adding a few more beta users to test V15. Currently it is the TurboCAD Mac brand which supports reading/writing ViaCAD and Shark files.
If you are interested please send me an email at Tim.olson AT encore.com. You must be a current user of V14.
V15 has a collection of enhancements plus the addition of Copilot which allows you to talk to documents or talk to your cad data.
For a video of Copilot see the link below:
CoPilot
https://youtu.be/9bknwOHL5-I
Tim " end quote.
I wish Tim was still around on the forum.
thanks 1 user thanked MaiFy for this useful post.
GARLIC on 1/29/2025(UTC)
