One more build with changes for ViaCAD and SharkCAD...
Change List 1652 --Do not show silhouette edges in render environment modes
--Corrected Shell open faces issues with Concept Explorer entity page displayed
--Rotate One Point menu not sticking
Download Download the WIP at :
http://www.masterviacad.com/beta/beta.php Note Please keep in mind this is a WIP with limited testing. I would recommend you rename your existing version as backup prior to installing 1651 Mac or Windows.
Edited by user Monday, March 11, 2024 1:16:04 PM(UTC)
Thanks: 14 times Was thanked: 22 time(s) in 14 post(s)
Gripper is still broken. I thought this was fixed? User position and at selected dont work!
1 user thanked CADCAM for this useful post.
Thanks: 587 times Was thanked: 96 time(s) in 62 post(s)
Thanks for your feedback ! - As a matter of interest what is your operating system ?- Mac OSX or WIN 10 / 11 ... quite often problems are math kernel related ! Best regards G.
Hi G,
Edition Windows 11 Home
Version 23H2
Installed on 29/01/2024
OS build 22631.3235
Experience Windows Feature Experience Pack 1000.22687.1000.0
It works in 1645 but hasn't worked since. However the inspector window doesnt show the rotate axis button properly.
Edited by user Tuesday, March 12, 2024 1:58:18 PM(UTC)
CADCAM attached the following image(s):
(16kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
I can confirm that. Using Windows 10 Pro Version 22H2 It works neither in build 1641 nor in build 1652. The window is to short to be displayed correctly. Wolfgang
1 user thanked Elektroniker for this useful post.
Confirmed, something is not right with the dialog size. Checking into... Tim
I am still with b1651 ...and the Shell Tool doesn't work !!!!
Originally Posted by: Jean-Francois Jacques I am still with b1651 ...and the Shell Tool doesn't work !!!!
JF, I could use some more information. Open Faces? Do you have Concept Explorer displayed? The latest build is 1652.
Edited by user Friday, March 15, 2024 1:05:11 PM(UTC)
Originally Posted by: Tim Olson Originally Posted by: Jean-Francois Jacques I am still with b1651 ...and the Shell Tool doesn't work !!!!
I downloaded the B1652 and the Shell Tool looks good ! Strangely I had an error message with 1651.
Thanks Tim for your fast answer !
