Variable Blend - very bad
Tim, definitely I don't have success with the variable Blend Tool !!
1- In concept explorer try to remove "Fillet (Variable)_REMOVE" = That will be delete also Fillet (Variable)_2
2- Look the inconsistent values for Fillet (Variable)_1 (I want 0.040" - 0.040" - 0.140" - 0.140")
3- Impossible to do a variable fillet for Fillet (Variable)_2 (all variable are 0.040 ") I want 0.040 - 0.140 - 0.040"
What is wrong !!
Add-On Pedals.sfx
(3,846kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked Jean-Francois Jacques for this useful post.
Thanks: 266 times Was thanked: 82 time(s) in 48 post(s)
I see the same problems (tested on my macbook w/ Sonoma)
kind regards
Danny
Edited by user Tuesday, February 6, 2024 11:53:57 AM(UTC)
BR Danny Win10 Pro, SharkCAD Pro v14(1653) v15(1722) Dell XPS 15 Sonoma 14.7.1 SharkCAD v14 Pro(1653), MacBook Pro 14 2023,M3
Originally Posted by: Jean-Francois Jacques Tim, definitely I don't have success with the variable Blend Tool !! 1- In concept explorer try to remove "Fillet (Variable)_REMOVE" = That will be delete also Fillet (Variable)_2 2- Look the inconsistent values for Fillet (Variable)_1 (I want 0.040" - 0.040" - 0.140" - 0.140") 3- Impossible to do a variable fillet for Fillet (Variable)_2 (all variable are 0.040 ") I want 0.040 - 0.140 - 0.040" What is wrong !!
Hi Jean-François,
I also noticed several bugs on the last build with the blend tools that I didn't have time to report yet.
Even constant blends :
Eliptic and
vertex are not working at all (the menu is not responding).
JL
Originally Posted by: jlm Originally Posted by: Jean-Francois Jacques Tim, definitely I don't have success with the variable Blend Tool !! 1- In concept explorer try to remove "Fillet (Variable)_REMOVE" = That will be delete also Fillet (Variable)_2 2- Look the inconsistent values for Fillet (Variable)_1 (I want 0.040" - 0.040" - 0.140" - 0.140") 3- Impossible to do a variable fillet for Fillet (Variable)_2 (all variable are 0.040 ") I want 0.040 - 0.140 - 0.040" What is wrong !!
Hi Jean-François,
Eliptic and
JL
Jim
Thanks for your comment !
I have also a big problem with the Push/Pull Tool. Inconsistent behaviour !!! Sometimes when I use it I loose the dialog window for my numerical value !!
I think Shark have a big problem with Sonoma!!
It will be nice to highlight the location points from the inspector to figure out where the variable blends are taken. To me the variable blend was crashing the software when I modified the radius at any location. Maybe that got fixed.
Originally Posted by: rockyroad_us It will be nice to highlight the location points from the inspector to figure out where the variable blends are taken. To me the variable blend was crashing the software when I modified the radius at any location. Maybe that got fixed.
Hi Rockyroad,
Variable blends seem to work perfectly now !
Though, with Constant blend, the choice menu
" Radial, elliptical, Vertex" is not working... it sticks to
"radial" .
JL
1 user thanked jlm for this useful post.
