tooltips missing when hovering over objects
Thanks: 8 times Was thanked: 8 time(s) in 5 post(s)
I use ViaCAD Pro v12 on an iMac running Big Sur (at work) and a on my new M3 Macbook Pro running Sonoma at home. I just installed this on the MBP.
When I mouse over an object at a corner, or the midpoint, for example, a tooltip appears showing me I'm on that point. However, on the new MBP they don't appear. Is this a preference setting somewhere (if so where, because I couldn't find it last night), or is this a bug with v12 on Sonoma?
perry attached the following image(s):
(17kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 270 times Was thanked: 82 time(s) in 48 post(s)
Do you have the relevant snaps enabled via Tools:Snaps in the menu bar ? kind regards Danny
BR Danny Win10 Pro, SharkCAD Pro v14(1653) v15(1722) Dell XPS 15 Sonoma 14.7.1 SharkCAD v14 Pro(1653), MacBook Pro 14 2023,M3
Yeah. I'm not at home right now, so this is on the iMac/Big Sur, where things work. but the Snaps window looks the same on my machine running Sonoma at home.
I should note that snaps on the machine where they're not showing up are working. That is, I can grab a corner and snap it to another corner. But when I hover over the corner on the object I want to move, it never shows me that it's grabbing that point.
(58kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Hi Perry,
Is "Display Snap Text" enabled in the settings (preferences)?
See screen dump.
kind regards
Danny
Edited by user Friday, January 26, 2024 9:39:52 PM(UTC)
| Reason: spelling
(513kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
It is enabled. I just double checked. this is starting to feel like a bug with v12 on Sonoma...
I think you are right about v12, I don't have other ideas.... I don't observe this problem with SharkCAD v14 (WIP build 1645) on my M3 macbook running Sonoma. kind regards Danny.
Thanks. I was hoping to avoid the upgrade, since I really don't need anything more than 12 offers, and it's been reliable for me. But I may have to because that makes it really hard to get anything done.
