Rozen
#1 Posted : Saturday, January 20, 2024 4:19:13 AM(UTC)
Rozen
I was looking for a surface roughness symbol (RA symbol )within Viacad/Shark but cant find it.
Please let me know if possible?
Thank you in advance!
damhave
#2 Posted : Saturday, January 20, 2024 12:33:56 PM(UTC)
damhave
Denmark
Was thanked: 35 time(s) in 22 post(s)
Hi, you find it in the concept explorer symbols. See attached image.
kind regards
Danny
Edited by user Saturday, January 20, 2024 12:35:38 PM(UTC)  | Reason: Not specified
Surface roughness symbol in Concept Explorer.png (654kb) downloaded 12 time(s).
BR
Danny
Windows 10 Pro,
SharkCAD v14 Pro (1653),
XPS 15,9980HK
Sonoma 14.3,
MacBook Pro 14 2023,M3
Rozen
#3 Posted : Sunday, January 21, 2024 7:18:03 AM(UTC)
Rozen
Thanks Danny,
I have another problem, maybe you can help.
I use Model Sheet to convert to 2D drawing views, but if I add new object in 3D mode, then it wont update the new object within Model Sheet even if I update manually.
If I just edit the existing object, then it update all Model Sheets perfect, but not if you just add a new object.
BR
Rozen
damhave
#4 Posted : Sunday, January 21, 2024 8:45:45 AM(UTC)
damhave
Denmark
Hi Rozen,
I cannot remember where in the manual I have read it but the procedure is:
Make a "New Draw View" somewhere on the Model Sheet where you find space for it.
Click on the new 3D object in its relevant layer. "Copy" your 3D object. Change to your Model Sheet. Select the new draw view you just created and "Paste".
Right click in the new draw view and then use "Change View" to choose the view you prefer. Right click again and use "Properties" Edges and select eg. Preceise curves.
Both object views in the Model Sheet should then update when you change the 3D objects.
As far as I know it is only possible have one 3D object in each draw view so you need to add new draw views for each new object you add.
Kind regards
Danny
Edited by user Sunday, January 21, 2024 8:47:27 AM(UTC)  | Reason: Not specified
BR
Danny
Windows 10 Pro,
XPS 15,9980HK
Sonoma 14.3,
Rozen
#5 Posted : Sunday, January 21, 2024 10:55:53 AM(UTC)
Rozen
Hello Danny,
You pointed me in the right direction thanks.
Actually you can just add as many new 3D objects to the same Model View, simply by copy the new 3D object, and paste it into the Model views.
Example: you made a flange with dimension, but later you draw the screws for the flange, the just copy and paste it into the model views.
Very simple :)
Thank you for your help
BR
Rozen
thanks 1 user thanked Rozen for this useful post.
damhave on 1/21/2024(UTC)
