ArizonaMetalworks
#1 Posted : Friday, November 24, 2023 4:57:55 PM(UTC)
ArizonaMetalworks
For the life of me I cannot figure out how to delete part of a polygon. I draw a rectangle, place 3 lines (like a U) against the long edge of the rectangle (like a channel) and cannot delete the top portion of the "channel"- that part of the rectangle that would open the channel. Can anyone tell me how to trim polygons?
Edit: I just watched a video where Tim drew two polygons, one on top of the other like the Red Cross symbol and then deleted the inside lines of the polygon. I cannot do that in V 14. Anyone know why? What am I doing wrong?
Edited by user Friday, November 24, 2023 5:19:14 PM(UTC)  | Reason: Not specified
damhave
#2 Posted : Friday, November 24, 2023 5:59:55 PM(UTC)
damhave
Denmark
Was thanked: 80 time(s) in 47 post(s)
Make sure to select the "single line" option in the polygon tool otherwise the trim tool will not work on the polygons created with the polygon tool.
Or use "Edit:Change Object Type" to change the object type of the polygons to lines before using the trim tool.
kind regards
Danny
Edited by user Friday, November 24, 2023 6:42:45 PM(UTC)  | Reason: Not specified
damhave attached the following image(s):
Polygon tool with single line selected.png (158kb) downloaded 3 time(s).
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
thanks 3 users thanked damhave for this useful post.
GARLIC on 11/25/2023(UTC), MPSchmied on 11/25/2023(UTC), ArizonaMetalworks on 11/27/2023(UTC)
ArizonaMetalworks
#3 Posted : Monday, November 27, 2023 8:06:01 PM(UTC)
ArizonaMetalworks
Originally Posted by: damhave Go to Quoted Post
kind regards
Danny
Worked like a charm! I hadn't noticed you can choose a smart polygon or a line when you draw them.
Thank you,
Bill
