ViaCAD/SharkCAD/TurboCAD Mac 1641 WIP
1641 Change Log —Correct a corrupt files issue when importing files with variable equations into another file.
—Correct a crash when exporting a point with no xyz data
—Corrected a crash when joining helix splines together
—Correction related to supporting animation tools on Windows
-Print issues
—Photo Render dialog settings corrections
—Correction related to photo Photo Render backgrounds when null
—Thin extrude issue
Update available at :
http://www.masterviacad.com/beta/beta.php Note this is a WIP and has not completed a full QA check.
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
This build 1641 is working very nice. No damaged files so far. I have only one crash when I imported some old AutoCAD files, but I worked around that no problem and no crashes since. Does any other cad program on the market let you add or subtract your coordinates or the object size consecutively mid command like Viacad? Makes Viacad very fast. Not that I know of unless you set up constraints, but I'm not very experienced in many other cad programs.
ViaCad 10 Pro ViaCad 9 Windows 10
1 user thanked creativecad for this useful post.
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Will version 14 and this WIP work with macOS 14 Sonoma?
