a.wieneke
#1 Posted : Monday, September 25, 2023 5:49:18 AM(UTC)
a.wieneke
Hello,
i downloaded a part of my city into blender,
exported as wavefront obj.
imported it into SharkCad V14.
so i have the houses and the terrain seperate.
Now i would like to make the terrain thicker.
I am a little lazy, because i could extrud every single surface.
is there any idea, how to thicken the whole terrain more smart?
forum.sfx (2,566kb) downloaded 10 time(s).
viele Grüße
Andreas
http://www.wieneke.biz
SharkCad pro 14
OS X 14.0
thanks 1 user thanked a.wieneke for this useful post.
MPSchmied on 9/25/2023(UTC)
damhave
#2 Posted : Monday, September 25, 2023 1:39:30 PM(UTC)
damhave
Denmark
The Mesh Extrude tool reports an ACIS error but it seems to be a solution (see attached image) for a relative flat surface like this although the thickness will have some small variations.
For better results (more consistent thickness) it may be needed to convert the extruded mesh to a solid (change object type) and split with an infinite plane to get a flat bottom side and use the shell tool to remove the unwanted faces.
Kind regards
Danny
thicken terrain.png (1,110kb) downloaded 12 time(s).
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
thanks 3 users thanked damhave for this useful post.
a.wieneke on 9/26/2023(UTC), MPSchmied on 9/26/2023(UTC), 24c on 9/26/2023(UTC)
a.wieneke
#3 Posted : Tuesday, September 26, 2023 1:55:06 AM(UTC)
a.wieneke
Originally Posted by: damhave Go to Quoted Post
Kind regards
Danny
THANK YOU VERY MUCH!
i knew shark has an easy way to do this.
I'm so blind :-(
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
murrayagain
#4 Posted : Sunday, October 1, 2023 9:11:02 PM(UTC)
murrayagain
Was thanked: 26 time(s) in 14 post(s)
In V10 and V14, extrude mesh will extrude a complete mesh surface as one into a closed, manifold mesh capped at both ends with the original if there's no selfintersection. It'll participate in solid mesh Booleans, subtracting a mesh block trims it to length. I don't know if there are limitations for facet numbers or other considerations. It works great, Tim and IMSI should be highlighting it.
Edited by user Sunday, October 1, 2023 9:12:27 PM(UTC)  | Reason: Not specified
murrayagain attached the following image(s):
extrude mesh.jpg (431kb) downloaded 2 time(s).
thanks 2 users thanked murrayagain for this useful post.
GARLIC on 10/2/2023(UTC), a.wieneke on 10/16/2023(UTC)
