Alexcad77
#1 Posted : Sunday, August 20, 2023 9:47:56 PM(UTC)
Alexcad77
I need help with converting a STL file to a solid. I imported a STL file and use a tool in the power pack to convert mesh to analytic. I got a message saying that "solid already separated." What does this message mean?
Am I doing the correct steps in order to convert an STL to a solid? I tried converting to a solid right after I imported the STL and I got a message saying "the maximum Number of facets is 3000." So I included some snapshots of the messages and what I'm trying to convert to a solid. Any help would be greatly appreciated.
Edited by user Sunday, August 20, 2023 9:48:32 PM(UTC)  | Reason: Not specified
Screen Shot 2023-08-20 at 11.26.46 PM.jpg (1,132kb) downloaded 8 time(s).
Screen Shot 2023-08-20 at 11.30.37 PM.jpg (883kb) downloaded 5 time(s).
Screen Shot 2023-08-20 at 11.39.03 PM.jpg (1,117kb) downloaded 6 time(s).
rokoko
#2 Posted : Monday, August 21, 2023 1:14:28 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
maybe watching a video can help https://www.youtube.com/watch?v=4rBXBfmfkX4
Alexcad77
#3 Posted : Monday, August 21, 2023 9:35:31 PM(UTC)
Alexcad77
I have the power pack but my version does not have those tools for the "3d print tool features". I have no idea why they're not showing up. I have version 12 pro and power pack. Am I missing part of the software?
Alexcad77
#4 Posted : Monday, August 21, 2023 11:23:36 PM(UTC)
Alexcad77
I figured out where the tools are now located. I watched the video to the link you posted and I watched many others. I'm still really confused because when I use the mesh to analytic tool it still shows a bunch of lines in red, and it doesn't appear to be one complete solid. When I try and put a hole in the center I can't because it is only selecting a tiny sliver and not the whole object. I'm assuming it's not turning it into a complete solid in someway? Please see attached photo. What am I doing wrong?
Screen Shot 2023-08-22 at 1.17.30 AM.jpg (1,386kb) downloaded 11 time(s).
Screen Shot 2023-08-22 at 1.13.13 AM.jpg (2,015kb) downloaded 8 time(s).
24c
#5 Posted : Tuesday, August 22, 2023 10:52:58 AM(UTC)
24c
Was thanked: 50 time(s) in 37 post(s)
@aAlexcad77
That's what Mesh2Solid does it takes the triangles and makes each one a solid AFAIK.
What you might be able to do is draw a circle on centre above the solid mesh and select all the solid objects and punch the circle through it.
Otherwise you could redraw the gear that way it'd be a solid.
Years ago I successfully converted a mesh to solid, I believe FreeCAD can do this', but most software that can is expensive.
Mike
PS if you provide a link to the stl, it might be good for others to experiment with
Alexcad77
#6 Posted : Thursday, August 24, 2023 2:00:30 AM(UTC)
Alexcad77
Hi Mike,
Thanks for your help. It seemed to have worked. I Extruded a cylinder and then subtracted it from the gear which left the hole. Which is what I was trying to do ultimately.
Alex,
Guest (7)
