ViaCAD, SharkCAD, TurboCAD Mac 14 Build 1635 is ready for WIP testing. You can receive links from:
http://www.masterviacad.com/beta/beta.php Change Log 1635 —Issues printing on Windows 11
—Printing text/dimensions within a draw view with flat/phong render
—Subtracting booleans where the object to subtract has more than 200 shells
--Additional support for user materials
Edited by user Saturday, July 8, 2023 9:27:16 PM(UTC)
Thanks: 1 times Was thanked: 5 time(s) in 1 post(s)
Hello Mr. Olson, Does Perspective work in this version on Win 10? Thank you
Thanks: 266 times Was thanked: 82 time(s) in 48 post(s)
@Tim
Thanks a lot!
But when will the user guides pdf and Web be updated (still outdated in 1635 WIP build - tested on my mac running OSX 11.7.8) ?
I cannot get the rendering to work. eg when using the denoiser with the default setting of 0 the rendering becomes a black silluette.
I may not use the new rendering correctly and it is difficult to guess how to use it.
Edited by user Sunday, July 9, 2023 1:28:46 AM(UTC)
BR Danny Win10 Pro, SharkCAD Pro v14(1653) v15(1722) Dell XPS 15 Sonoma 14.7.1 SharkCAD v14 Pro(1653), MacBook Pro 14 2023,M3
If you send/post your file and I'll make a quick video of how I would go about rendering the file.
Edited by user Sunday, July 9, 2023 4:03:39 PM(UTC)
Dear Tim, Thank you very much! In the meantime I have changed back to Windows 10 (my primary platfrom), and I do not observe problems here - rendering works correctly :-) no problems on Windows 10 at all except for the rendering documentation (pdf and web user guides) which strongly need updates to be consistent with the current version of SharkCad. Changed back to my mac (wanted to check if I made a simple user error), the problem still persist on my mac even with a hello world project "a simple sphere primitive placed at the orign with yellow plastic material applied" and is seen both in top and front view. It may be my old macbook pro and releative old OSX 11.7.8 installation that behaves strange and needs an update or some settings "hanging" from the previous sharkcad version, but it is vacation and it takes to much time to do a system update and try to track this bug down. I stay on Windows 10 where everything works perfectly for a while - at least during my vacation :-) kind regards Danny
Thanks: 7 times Was thanked: 79 time(s) in 45 post(s)
I have a problem in creating a counter hole in the Y axis. It places the hole on the upper side of the model.
(641kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 21 times Was thanked: 8 time(s) in 6 post(s)
Is anybody testing the latest WIP on MacOS Ventura? Are we supposed to test on MacOS
Tim's post ?
1635 is quite usable for what I do, my drawings are quite simple. I wish the UI would be modernized a bit but haven't found a real show stopper yet.
Edited by user Thursday, July 20, 2023 8:34:51 PM(UTC)
