Thanks: 14 times Was thanked: 22 time(s) in 14 post(s)
Tim posted a couple of the renders on this site. Is this actually possible on V14?
I have been playing around all day with the settings and I get pathetic results at best. If anyone wants to share there render settings to give quality pictures that would be appreciated.
Also in V12 there were quick render options which don't seem to exist in V14?
(1,511kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Yes, v14 was used to create. I get more realistic images with V14 than V12 especially with glass or metal.
Perhaps I need to make a more in depth video how to apply materials and render scenes....
(1,361kb) downloaded 20 time(s). You cannot view/download attachments. Try to login or register.
Your right, the renders are very fine..... specifically Meteor Motor !!
Originally Posted by: Tim Olson >>Is this actually possible on V14? Yes, v14 was used to create. I get more realistic images with V14 than V12 especially with glass or metal. Perhaps I need to make a more in depth video how to apply materials and render scenes.... Tim
I don't know how you are getting these results, so I definitely look forward to a much more detailed video or manual on this!!
Also in one of your videos you said that the luxcorerender supports GPU processing but all the render engines are CPU based. My understanding is you need OpenCL. Will you be adding these?
