Thanks: 34 times Was thanked: 39 time(s) in 31 post(s)
@damhave
Only thing I've see is this in the PDF help
Mike
(405kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
macOS 14.3.1 (Sonoma) - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1652
Thanks: 123 times Was thanked: 32 time(s) in 20 post(s)
@24c Thanks a lot.
My best guess is now that the MidPlane Tool is more or less the reverse function of the "Extrude Mid Plane tool". My hope was that it worked like the MidPlane in Solidworks where two opposing surfaces are used to specify a MidPlane, but this seems not to be the case. Maybe it is intended to be used to simplify bending or unfolding operations for sheet metal?
Edited by user Wednesday, May 24, 2023 12:59:25 PM(UTC)
BR Danny Windows 10 Pro, SharkCAD v14 Pro (1653), XPS 15,9980HK Sonoma 14.3, SharkCAD v14 Pro (1653), MacBook Pro 14 2023,M3
