lightbulbjim
#1 Posted : Sunday, May 7, 2023 4:24:45 PM(UTC)
lightbulbjim
Was thanked: 16 time(s) in 13 post(s)
Is the Help -> Current Version function supposed to work? Ever since I started using Via/Shark (several years ago) I've never had it tell me that a new version is available.
I'm currently running a WIP build (1624 on Mac) if that makes a difference, although I haven't seen any updates from mainline builds either.
thanks 1 user thanked lightbulbjim for this useful post.
damhave on 5/8/2023(UTC)
#2 Posted : Monday, May 8, 2023 1:29:53 AM(UTC)
With this feature, you will not receive the work-in-progress (WIP) builds, as they may not be stable enough due to insufficient testing.
lightbulbjim
#3 Posted : Monday, May 8, 2023 4:06:32 AM(UTC)
lightbulbjim
Understood, but I've never seen it report any updated version available, not even stable releases. Does it work for anybody else?
damhave
#4 Posted : Monday, May 8, 2023 5:15:12 AM(UTC)
damhave
Denmark
Same here... I have never seen any updates via the program menu. But at least I find that the WIP builds are stable and normally works good (at least on Windows). Currently I run SharkCad Pro build 1628 (WIP) on windows 10 and it runs excellent :-)
Edited by user Monday, May 8, 2023 5:24:31 AM(UTC)  | Reason: added (WIP)
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
